Advice on building a dummy resistor load
Discussion in 'DIY' started by SaSi, Sep 29, 2015.
  1. SaSi
    SaSi Seriously Illogical Subscriber
    4,207
    Athens, Greece
    If I wire several high power (say 10W) resistors in parallel, I can easily figure out what the total resistance value will be (1/R = 1/R1 + 1/R2 + ... + 1/Rn) with the total power "capacity" being the sum of the individual ratings, so 10x 10W resistors will give me 100W capacity, right?
    Now, what happens if I wire two such blocks in series? Total resistance will be the sum of the two but what about power capacity? Will that double as well?
  2. DRecovery
    DRecovery Pants-wearer Subscriber
    779
    Rochester, Vermont
    The power will only share evenly if the resistors are identical, otherwise you are right.
    The second block of parallel resistors will double the power capacity.
    The situation can be a bit more complicated as power ratings often have caveats. All assume they are allowed to reach obnoxiously high temperatures in the 150-250C range, the high end of which is usually unacceptable for non-cooking related applications. Finned resistors may assume some amount of forced air flow to reach their power rating, and most assume a certain amount of dead space around them. Pack therm in too closely and they will reach peak temps before their max power rating and start scorching the board, wires, caps, etc., basically you then have a Pioneer receiver power supply, really.
    Ray Gianelli likes this.
  3. gadget73
    37,736
    Southern NJ
    You can also cheat and dunk them in liquid to increase capacity quite a bit.
  4. SaSi
    4,207
    Athens, Greece
    Thanks, I need to burn about 150W of power at 4Ohms.
    Will look for high powered resistors to use as few as possible.
  5. whoaru99
    whoaru99 Epic Member
    40,899
    LoTL
    I've seen people make high power dummy loads by using water heater elements mounted to the pail cover and submerged in 5gal pails of water.
  6. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,450
    Fort Dodge, Iowa
  7. blhagstrom
    12,895
    Duvall, Washington
    ?!?!?!? water heater elements are 4-8 ohm????
  8. whoaru99
    40,899
    LoTL
    Series-parallel arrangement. In this example primary use was 4 ohms testing pro audio amps. 4 was not hit exactly, but 4.32 ohms is pretty close and knowing that it's easy enough to normalize the results.
    It's switchable to 8 ohms and 2 ohms as well. Again, neither were hit dead on but like 8.4 and 2.2 actual.
  9. omishra
    omishra Active Member
    363
    PNQ, India
    I use room heater filament coil encircled on wood and with 2 crocodile clips on ends. Measure the resistance with DMM and use this resistance load upto 2KW power.
  10. gadget73
    37,736
    Southern NJ
    Just have to watch using inductive loads like that. It will screw up what the scope tells you if that happens to be important to you.
  11. goat67
    goat67 AK Subscriber Subscriber
    5,195
    Twin Cities MN
  12. stoN_Cold
    stoN_Cold Super Member
    3,466
    Belgrade, Serbia
    I made these:
    - 4 x 8Ω
    - 2 x 4Ω
    - 1 x 2Ω
    maxhifi and Ray Gianelli like this.
  13. gadget73
    37,736
    Southern NJ
    i was thinking of building something like that ^^^. I've got a carcass of a car amplifier that would make the perfect heat sink. I have a couple of 5 ohm 100w wirewound at the moment but its an odd impedance and they are inductive. Good enough for a dummy load, but not what I really want to get measurements with.
  14. ConradH
    ConradH Addicted Member
    8,082
    Canandaigua, NY
    I scored a bunch of 40 ohm power resistors at a hamfest, so my load is 5 x 40 in parallel, good for about 250 W continuous and a whole bunch intermittent. Most low value wire wound resistors aren't inductive enough to worry about unless you do a lot of high power testing at 20 kHz, and then I'd expect to do more fixing than testing. I try to keep my high power high frequency testing to a minimum.
  15. stoN_Cold
    3,466
    Belgrade, Serbia
    Dale is the best.
  16. sKiZo
  17. shelly_d
    shelly_d Not An Audiophool
    6,666
    Alameda CA
    I have 4 of the 8 ohm 100 watt parts express resistors:
    http://www.parts-express.com/8-ohm-100w-non-inductive-dummy-load-resistor--019-020
    That can combine into 4 ohms / 200 watts times 2 or 16 ohms / 200 watts times 2, 8 ohms / 100 wats times 4 or 8 ohms / 400 watts times 1.
    Even on a 200 watt per channel monster amp I was safely able to use the 100 watt resistors by careful monitoring the voltage applied to the resistors and keeping it under 20 V rms (50 watts into 8 ohms)
    JWINEE likes this.
  18. JURB
    JURB Super Member
    3,330
    NE Ohio
    Ha, you can say that again. Just long enough for the distortion meter to get in tune. Very rarely is an amp expected to do full power at 20 KHz.
  19. Ray Gianelli
    Ray Gianelli AK Subscriber Subscriber
    1,181
    Lake Worth, FL
    Very Nice!
    The cooling fans are a nice touch.
    Hipocrates likes this.
