Hi all-
okay, I took the front off the machine, unstuck the stop lever, cleaned everything with alcohol and q-tip and....it works! I mean, it sounds kinda cheesy through the built-in speakers but the sucker really works! Now I have
a couple more questions if you all don't mind;
1.There's a little pin sticking out over the head cover-doesn't seem to be in the tape path necessarily although it is in the same general plane. It has some kind of bent clip mounted to it. Any idea what it is?
2. I'm missing a reel retainer-the rubber boot over the hub-and the reel wants to gradually slide off. Any ideas on where to get replacements? I put a piece of fuel line hose over it for now but that's kinda cheeseball, y'know? Some I've seen have built-in locks on them but not this guy.
3. Since this thing apparently has its own amp, is it safe to just plug it into the tape/aux inputs on my receiver like any other component? If so, where should I have the volume set?
Thanks in advance and please pardon my ignorance
Dan
Dan
