Hello, as I said in my intro to the forum I bought an Akai AA 1150 a few weeks later. It has some problems with it, first I'll post some pics of my receiver then some questions, thanks!
PROBLEM n°1
I have a cable flying around and I need to know where to connect it to... here is a part of the schematic (which I don't understand).
At the bottom it's a number 3 thats the wire I have flying around. I don't know what C903 and C902 means or why it says VLT...
That's the first and most easy problem to solve (I think it goes attached to the wire of one of the filter caps? If its that the case which one?)
PROBLEM n°2
It seems that the previous owner have the originals filter caps replaced with these 4 horrible caps... (4700uf 63v). I think it would be better if I replaced those horrible horrible capacitors with ones of 10000uf 50v. Is the wiring okay? What is that tiny cap above those two big blue ones? If I replace those do I still need that tiny devilish cap?
PROBLEM n°3
What are those two brown cables? They were welded to the pins 9 - 10. What do they do?
PROBLEM nº4
What is that black thing attached to the resistance? And why is there a resistance????
PROBLEM nº5
I don't think this is a problem but I need some advice about how can I test this with my multimeter and which kind of grease should I use.
PROBLEM nº6
This selector and the one from left up (source and selector) are way to difficult to change they are kind of stuck... What can I put to clean them and make them move more easily?
PROBLEM nº7
Which replacement should I use?
PROBLEM nº8
What should I say when I take the transformer to be rewired? I mean... If I give them the transformer they can do it exactly as it was before it burnt? Or should give them some specs?
Well... those are my problems for now... I'll appreciate every little or big effort you could make to help me get this thing operational. Everyday I'm learning more and more about electronic from youtube (and now here) and I really like it (I read the thread "Amplifier Sensitivity, Decibels, and You!" and it solve some questions I have had in my head for a long time).
Manual: http://www.hifiengine.com/hfe_downloads/index.php?akai/akai_aa-1135_1150_service.pdf
PROBLEM n°1
PROBLEM n°2
PROBLEM n°3
PROBLEM nº4
PROBLEM nº5
PROBLEM nº6
PROBLEM nº7
PROBLEM nº8
