tensleep
Addicted Member
I have an SLC 500 that is registering a fault. I have been able to reset the fault and keep on running the production line, but before I hook up the laptop and start digging deeper, I would like to know if any of you have extensive experience with this particular PLC. It has been over 10 years since I have really dug into one and would like a bit of insight. I am in touch with my local vendor and factory rep and can bring in an AB engineer if necessary, but I like to figure out these kinds of problems for myself, where possible.
The CPU Fault LED is flashing, but can be reset. The troubleshooting manual says this represents a major CPU fault that could be caused by a hardware/software fault or erratic repetitive power cycling. The remedy is to monitor Status File Word S:6 and clear Satus Files S:1/13,5 &6, then set the processor to run. I have been able to toggle the keyswith to program, then back to run, clearing these files. My next step is to see if I can get one of these ancient laptops to communicate with the PLC so I can pull the code out of S:6.
I'm all ears.
I'm all ears.
