Thanks. I have seen that site.OK, I guess you have it already, but I found this for you on Pinterest; 1505B apparently. More info here: http://jeffsplace.me/wordpress/?p=9515
I would put together some measurements for you but mine are tar filled. All I could help with would be exit dims and overall length to throat.
All I need is the outer part of the profile and the front and the back edges. I can use the other info to make it work.
604man's post directs you to some good engineering data for building your own exponential horns. Interesting reading.
Thanks
BillWojo
