Altec Segovia 874A worth saving?
Discussion in 'Speakers' started by njcanuck, Jan 14, 2013.
  1. njcanuck
    njcanuck aka: MacGyver Subscriber
    2,785
    Cape Coral, Florida
    A friend donated to me a pair of Altec Segovia 874A (wife wanted them outta the basement!) this weekend. A little research says they were produced in the early 70s as an oversized bookshelf speaker and Altec’s competitor to the JBL L100 and the AR3a.
    These look like they’ve had a bit of a hard life and one has some hacked repair attempted. They are not consecutive serial numbers (33xx and 39xx) and are clearly slightly different construction. Does anyone have these? Are they worth spending any time on?
    They are not functional at present. On one, I got sound out of the tweet and mid but no woof. On the other, woof only. The foams are rotted out on the woofs but the VCs on all the drivers measure close to 4 ohms. One woof has fried tinsel wires but the VC still measures 3.7 ohms. The crossovers likely need recapping as a minimum. The cabs are scratched up but only lightly on very good veneer.
    I was thinking of attempting a restore if only for the practice. However, if they were originally dogs and always will be, I’ll pass and look for a different project. What would you do with them?
  2. botrytis
    The woofers in the Segovia's are specific to it. It is used in no other Altec speaker. They are a great sounding speaker (I am currently working on a pair).
  3. bowtie427ss
    bowtie427ss arigato gozaimashita Subscriber
    16,590
    Land of Milk & Honey Boo Boo
    I would definitely restore them. They're a less common Altec and were fairly expensive when new. That dynamic force woofer is supposed to make fantastic bass.
  4. bowtie427ss
    16,590
    True.
    However, the 891A woofer is pretty close.:D
  5. mhardy6647
    51,405
  6. nexus
    nexus Super Member
    1,587
    the signpost up ahead
    i remember a version of this speaker (shown full color in the warehouse sound catalog circa 1975) that had a cone tweeter and small midrange/tweeter with round frames....maybe a different model from that same era?
  7. mhardy6647
    51,405
    Sounds more like the later (ca. 1975) Altec model 1 - 3 - 5 - 7 - 9 series to me than the Segovia-era (ca. 1971) speakers:
    http://www.lansingheritage.org//html/altec/catalogs/1975-home.htm
  8. botrytis
    As I said, the woofer in this speaker was only used in this model. It is a monster, underhung, etc - very amazing design for the year.
    I can't wait to get mine back up and running. The crossover caps are the biggest issue - look at the ratings and look up the size of the ones you can replace them with.
  9. mhardy6647
    51,405
    Altec knew a thing or two about designing loudspeaker drivers ;-)
  10. bowtie427ss
    16,590
    Original, i promise.
    Segovia is a unique creature in terms of vintage Altecs.
    Altec affectionately named these woofers "Dynamic Force" because of the huge dynamic force capabilities of their motors.
    These smaller versions in the 874 and 891, as well as the larger 413 woofer are based on the 411-8A, the only Altec woofer to use a 4 inch voice coil.
    FWIW, there's a duplex with a 4 inch VC. However, that LF section is actually a JBL LE-15.
  11. njcanuck
    2,785
    Cape Coral, Florida
    I'm pretty certain that the tweeters are original. I got the speakers directly from the original owner and he's not the type to mod stuff. Here's a pic of the part #s:
  12. mhardy6647
    51,405
    They are - Altec used OEM 4 ohm Philips AD0160 polycarbonate domes in these - I did not know Altec ever used those tweeters (which are very nice sounding drivers, AVID in Rhode Island, e.g., used them in their 1970s loudspeakers) until today.
    I really should stop pretending I know anything about Altec products :p
  13. bowtie427ss
    16,590
    Heck no!
    Don't let the Segovia's throw ya, they're a far departure from the Altec norm, unique in every way to their predecessors.
  14. halo71
    halo71 Super Member
    2,281
    Augusta, GA.
    I passed over a pair of those at a flea market several years ago. I thought they were some lower line junk that Altec made. Only if I'd had a smart phone then! lol
  15. nexus
    nexus Super Member
    1,587
    that's the one! the model 5. thanks for the pics! (and excellent woofer build for those days)
    EDIT: reading the product brochure, i find it interesting that altec was researching psycho-acoustics but failed to build their speakers in mirror imaged pairs! (but few companies, except for say, ESS were doing that back then).
  16. njcanuck
    2,785
    Cape Coral, Florida
    I got a chance to test all the drivers tonight. Good news - they all work, even the woofer with the fried wires! The crossover transformers seem to be good as well. Don't know about the caps but I figure on replacing them all.
    Since the key parts seem viable, I guess I'll order some foams and tinsel leads and start restoring. Anyone have a good source for the caps - 6uF, 30uF, 100uF all 50V ?
  17. mhardy6647
    51,405
    The Dayton loudspeaker crossover caps (Bennic OEM, if memory serves) from Parts Express are inexpensive and are also quite respectable.
  18. avguytx
    avguytx AK Subscriber Subscriber
    8,869
    Central AR
    Madisound is where I get all of my capacitors, etc, from as I use Solen for most everything. Some like Parts Express but their shipping charges turn me away. You can go higher on voltage than 50v and you'll be fine. The Solen caps are 400v and I've used those in old Altecs, Klipsch, AR's, Dynaco's, Polk, etc, etc. But I'd go with an electrolytic cap for that 100uf cap as it would be way pricey in a Poly. Even the 30uf will be rather pricey in the grand scheme of things.
    6uf Solen
    30uf Solen
    100uf Solen
    100uf electrolytic Bennic (I've used these...work well)
  19. njcanuck
    2,785
    Cape Coral, Florida
    Thanks guys. Those caps are in the right price range. I used Sonicaps in my Klipsch but these Altecs are not going to be a high-buck restore. The Solens are available in all the correct sizes so I'll probably go with them.
  20. diamondsouled
    diamondsouled Recycle belly button lint! Subscriber
    8,030
    Canada
    You can also order direct from Solen in Canada. They have great pricing and a nice selections of inductors and speakers as well. If you order lots of stuff they can even be talked into giving dealer pricing.
    http://www.solen.ca/pub/index.php?s1=1&a=2
