Hi. I just bought a pair of Altec 601c coaxes (the little brother to the 604) from the auction site. They arrived today. One speaker seems fine. The other was showing an open circuit on the tweeter (they were sold as is at a cheap price). I partially removed the felt cap behind the tweeter horn, and found that one of the tweeter leads was broken, right where the tweeter lead comes through the woofer cone. Measuring the leads there says I have a good tweeter, which is excellent news because these tweeters are not repairable.
So now I need to figure out the best way to repair this tweeter lead. Right now I have a short lead from the tweeter to the cone, a small hole in the cone where the lead goes through, and a lead from the tweeter terminal to the cone, with a metal grommet on the end where it went through the cone. There is very little slack on the lead from the tweeter to the cone considering cone movement, so I don't have much material to work with on that end. I could run a new wire from the terminal through the cone to the tweeter lead and solder them, but then I need to close up the hole in the cone and reattach the felt dustcap behind the horn, but with what? Silicone bathtub caulk comes to mind, but I'd like to know if anyone has any better ideas.
Thanks!
Thanks!
