No but if you get into the guts of the subwoofer and amp, you should be able to disconnect the amplifier and do at least something like what you want to do.
The trick will be whether it used an active crossover
and/or some sort of contouring (EQ) provided by the amp module. If so, you'll have to either add a passive crossover and/or use an outboard, active subwoofer amplifier. The driver
may or may not be worth the investment.
Do you know if the driver in it has a single or dual voice coil?
What kind of subwoofer is it?
PS many on-board and outboard subwoofer amplifier options exist; PE has some cool ones (I recently bought one of the "250 watt" class D plate amps with DSP for an active subwoofer project, e.g.)
https://www.parts-express.com/cat/subwoofer-plate-amplifiers/332
https://www.parts-express.com/dayton-audio-sa1000-subwoofer-amplifier-rack-mountable--300-811
https://www.parts-express.com/dayton-audio-sa230-230w-subwoofer-amplifier--300-813
