Chilerwater
New Member
Dear Moderators, pls locate this thread were applicable. Thank you.
Hello,
This time I´ve obtained Denon PMA-680R from a well known auction. The amp is apparently dead. The The amplifier turns on perfectly but the speakers are not heard.
I have reviewed the electronics and the problem is because the protection relay does not reach tension. I put in the post plane of the circuit.
I changed the capacitors and checked the transistors and resistors not detecting any fault. What I notice is that I cannot see 8,9 volts after the R415 and that it goes to the base of the transistor T405.
any clue in order to continue?
regards,
Hello,
regards,
