zygotemrsmit
New Member
I have found that this woofer is a good fit in my original AMT cabinets. (fit my oem cutout without modification) It definitely is more accommodating than the OEM where power handling is concerned. You may need to watch your fuses in the AMTs.
I have only tested it in the pyramid unit. (not the tower) You may want to change port size depending on your ear.
Goldwood GW-10PC-4 10" Heavy Duty Woofer 4 Ohm
I ordered from parts express, however; I am sure there are other outlets.
