Analog to Dolby Processor
Discussion in 'Home Theater & Video' started by Beatnik, Mar 28, 2018.
  1. Beatnik
    Beatnik What's this ?
    4,658
    DFW
    Always looking for a small decoder I can use with whatever amp I want or have and I stumbled across this unit. What do you think of this ? Do you think it would give a true 5.1 from a R/L computer output (pro logic II or better) ?
    RH-619 audio decoding system can decode DTS Dolby Digital AC-3, DTS, LPCM and other digital audio format source; support U disk playback WAV and DTS5.1 multiple audio and video; connect computer USB, achieve USB5.1 sound card, through the internal quality of DAC conversion output 5.1 channel analog audio. In support of the two output mode and a variety of EQ mode, can match with different power amplifier and speakers, to get a differentsound effects. Optical fiber and coaxial digital audio output end is butted with DVD players, Blu-ray machine, network player, set-top box, PS2, PS3, Xbox360, PC and many other entertainment equipment use.
    1. Supports one digital coaxial input, one digital optical input, one analog stereo AUX input, one USB-PC computer sound card input, one USB2.0 interface input, you can freely switch between different sources.
    2. Support 6 channel analog audio output of RCA and 1 AV video output, can be directly with the power amplifier, active sound box or TV docking
    3. Using 24 bit / 96KHz audio DSP, the fourth generation of 24bit / 192KHz CS4354 DAC chip, a power-on reset function
    4. support stereo seven EQ mode output selection can play mode
    5. support Dolby digital AC3, DTS, LPCM, HDCD, PCM, Dolby digital, Dolby Prologic II and other digital audio format decoding
    6. support U disk multimedia player, can play 5.1 channel music, video, pictures, mirror,TXT document and other multimedia content
    7. USB port USB port on a mobile device provide 5V1A charge
    8. The automatic identification of the digital audio signal input format, 5.1 channel noise test function
    9. DTS/AC3 decoding and playing in support of the 2.0 and 5.1 channel two output modes, stereo decoding playback support 2.0 2.1 and 5.1 output options, according to the number of flexible configuration of sound box
    10. The high quality sound, low noise, computer mute and reset function, better after protection level and equipment
    11. A key switch input source, easy to operate, easy to operate and support the panel buttons to adjust the volume coding
    12. Support 3.5mm infrared remote control extended operation, extended remote control operation, the visual menu settings interface
    13. The power-off memory function, after reboot automatically switch to the last used signal channel, USB broadcastmemory before the power file
    14. The use of DC 12V/1A external power adapter power supply, wide voltage can use DC (7-20V) power supply
  2. Duane
    Duane AK Member Subscriber
    3,831
    San Diego
    Unless your computer has a digital output, you'll not get true 5.1 (DD,DTS). You should be able to get Pro Logic from the stereo outputs.
  3. Beatnik
    4,658
    DFW
    I don't have ta digital output on my old computer. It's currently going into an old pro logic preamp, but was curious. Is there a way to convert the signal externally to digital and achieve this ???
  4. the skipper
    the skipper Amateur Curmudgeon Subscriber
    2,941
    Aggieland
    You could convert an analog signal to digital but it will still be only two channels. You can't make a "real" 5,1 signal from something recorded in two channels. It has to be 5.1 to begin with. It might be time for a new sound card.
    DChen likes this.
  5. Beatnik
    4,658
    DFW
    Doesn't Pro Logic decode two channel analog to 5.1 with mono rear channels and II adds stereo rears ? Is this not actually six separate channels from two ?
  6. 1tumbleweed
    1tumbleweed Kozmik Kowboy Subscriber
    6,123
    Colorado Front Range
    No. Both Pro Logic and Pro Logic II use a two channel source to generate a surround effect - not "six separate channels". Although what comes out of the center front and two rears (and the ".1") are different from each other and the front two, they're all obtained by manipulating the original two. Only Dolby Digital and dts can deliver discrete channels.
    DChen likes this.
  7. the skipper
    2,941
    Aggieland
    No. DPL converts two channels to "something" with different stuff coming from the speakers but it's nowhere near the true discrete channels a digital signal will produce.
    KentTeffeteller and 1tumbleweed like this.
  8. Duane
    3,831
    San Diego
    I think people tend to use the 5.1 description for all surround sound formats, but ,as mentioned, it's really for discrete channels only. For Dolby surround and the Pro Logics, older receivers and processors would display it as 3/2.
  9. Beatnik
    4,658
    DFW
    That's what I needed to know. Thanks
  10. Djcoolray
    Djcoolray Addicted Member
    6,546
    A rocks throw from JBLM !!!!
    It would be easier and cheaper to put a DAC between a computer and a good AVR....
  11. whoaru99
    whoaru99 Epic Member
    40,917
    LoTL
    If you are currently using a DPL setup to get matrix surround sound from 2-ch analog sources, anything that would instead apply DPLII to that 2-ch analog signal would be a big improvement. Not as big improvement as fully discrete surround, e.g. Dolby Digital, but none the less DPLII is a BIG improvement over DPL.
    Beatnik likes this.
  12. Beatnik
    4,658
    DFW
    Ok, now I believe I have digital 5.1 from my computer using the cheapest external sound card money can buy (I believe it's a CM6206-LX chip ? I haven't opened it and doesn't specify where I purchased it). This on Ubuntu through VLC and using the Disney WOW setup dvd and a Dolby Digital demo test dvd checking that I actually have true six separate channels. It all sounded right while playing the Rush 2112 Five Point One dvd-a disc with different sounds coming from all four corners.
  13. KentTeffeteller
    26,146
    Athens, TN
    Only truly discrete analog surround sound is from 4 channel tape formats. All else is matrix.
  14. tjohnusa
    tjohnusa AK Subscriber Subscriber
    344
    You can still get some nice sound from an older avr. I was running a NAD 716 I bought on craigslist for $50 that produced some decent surround from a analog rca cable from my directv receiver if you are trying to do it on the cheap. I still have that receiver just collecting dust if your interested.
    Beatnik likes this.
  15. Beatnik
    4,658
    DFW
    Thank you for the offer ! I have a Parasound pro logic pre already. I grabbed the cheapest usb unit for laughs and according to my computer settings and a couple of test discs (WOW and Dolby Digital) I'm now getting true 5.1
    When I put in my Rush 2112 DVD Audio disc I get everything, including separate left/right rears, at least to my ears I'm hearing it that way (around the room, not just front rear).
