Another hearing / tinnitus thread
Discussion in 'General Audio Discussion' started by Audiotfoot, Nov 7, 2018.
  1. Audiotfoot
    Audiotfoot AK Subscriber Subscriber
    176
    Lewistown, Montana, USA
    Can tinnitus mask sounds that one actually hears?
    According to the audiologist my hearing above 6K disappears. Playing around with pure tone generators shows that with lots of amplification an 8K tone can be faintly detected. Above that there is occasionally a faint hiss.
    Tinnitus has been a companion as far back as memory stretches.
    A while back a session dinking around with the parametric equalizer included with GoldWave gave some indications that I was able to pick up music above 6K fairly well. This last weekend some serious exploring was done.
    The equalizer was set for ten bands. AFAIK this is a low pass equalizer. The top band stretches from 10K to 20K and can be moved so that it can cover the range above 20K to 50K. When that slider was in the 10K to 20K range and was pulled completely down all the highs disappeared. When pushed to the top what I refer to as a brittle high was present. Back to the middle music sounded, well, good.
    Extensive playing around showed that once the bottom end of the band went above 13K moving the slider made no difference.
    My conclusion is that tinnitus masks high frequency pure tone signals, but lets those frequencies as music be recognized. Possible?
    Anybody else found the same thing?
  2. tubed
    tubed Lunatic Member
    15,889
    Aztlan
    After experiencing a harrowing Meniere's attack I lost hearing levels below 250hz and anything above 8k.
    Those sounds inbetween were distorted and ugly.
    The doctor informed me this was permanent.
    Lucky for me doctors are basically clueless as my hearing slowly came back to very close to normal.
    My hearing does wane a bit with some tinnitus, especially when stressed andor poor diet.
    Interestingly, the frequency level that does roll off, can be heard by increasing volume output of those frequencies.
    Some researchers believe even if the ears can't "hear", the subconscious brain does.
    Parkermike likes this.
  3. musichal
    11,626
    Norman OK
    Good thing I'm a psycho-acousticalologist, then. My diagnosis, in these cases, is that - no wait, I'm not a psycho-acousticalologist. it was a psycho... a psycho... a psycho-something. I'll have to ask my therapist.
    Leland47, nedseg, jimreeves and 5 others like this.
  4. Lapslah
    Lapslah Well-Known Member
    613
    Illinois
    I've had severe tinnitus for over 30 years now, and mine definitely masks sounds in the 6-10k range. The audiologist says I need hearing aids, but when I ask if they can compensate for tinnitus, she says not really. but they introduce other sounds to try to mask it. No thanks. The last thing I need is even more phantom noises in my head.
    jimreeves and 81spirit like this.
  5. hjames
    hjames beware - winter is HERE! Staff Member Moderator Subscriber
    12,527
    VA near DC
    You mean I'm not supposed to hear the roar of the ocean day and night?
    ElCovina, Leland47, 604man and 6 others like this.
  6. tom67
    tom67 Active Member
    416
    Palm Beach Gardens FL
    I have posted this before....you and I have a similar problem and hearing range...mine about 11,000 tops, but require much higher volume for notes above 8K......We are in luck because most notes of musical interest fall well within our range. High female soprano voice is 1,050. The guitar is the most frequently used instrument in modern music and it is below 2K. Even an edgy violin is below 4k. The point is, you can certainly continue to enjoy music including much of the nuance......
    http://www.zytrax.com/tech/audio/audio.html
    rickb119 likes this.
  7. Tim64
    Tim64 Super Member
    1,214
    Southern Oregon
    I have had tinnitus since I was a kid bad genetics evidently but I can still hear up 14K. Some days it's in my face loud and others it chills out and is barely noticeable. I wear hearing protection religiously and do not crank the tunes. My mother also suffers from Meniere's disease and I hope it's not in my future. I have learned to not dwell on it since there is not a thing you can do about it, otherwise it can make life miserable.
    Bodyblue likes this.
  8. Audiotfoot
    176
    Thanks for the link, good information to have. I consider myself fortunate, even without hearing aides the full range of most music is available. Hearing aides have helped with the upper end, violins are now clearly heard and triangles are present again at normal listening levels. What intrigues me is that frequencies above 9K aren't consciously identified, but when removed a real difference in sound is noted. I didn't expect that.
    As for enjoying music, some in my family consider me a music addict. If so, what better addiction to have?
    tom67 likes this.
  9. SoCal Sam
    SoCal Sam Lunatic Member
    19,145
    Picker's Paradise
    Tinnitus is the sound of over-pressurized blood coursing through your veins. OK maybe not but good health sharpens the senses and the mind.
  10. Bodyblue
    Bodyblue AK Subscriber Subscriber
    3,839
    CA
    Exactly my situation.
  11. Bodyblue
    3,839
    CA
    Mine sounds like a slow air leak.........it came on so slow that I just got used to it for the most part. It gets worse when I am tired. As a result I NEVER wear headphones.
  12. Pio1980
    Pio1980 AK Member Subscriber
    27,741
    Eastern Bamastan
    I use Grado 60 on a tablet with eq comp.
  13. tom67
    tom67 Active Member
    416
    Beethoven was hearing impaired his entire life and ultimately deaf ...obviously didn't affect his passion..
    Leland47 likes this.
  14. Pio1980
    27,741
    Eastern Bamastan
    Coincidentally, now checking out a Beltone Audio Scout portable audiometer I found at an indoor flea market. Appears fully functional with intermittent ps cord.
  15. tom67
    tom67 Active Member
    416
    Yeah, along those lines....I got back to vinyl about a year ago. I have duplicate material on vinyl and CD. I sensed something missing when I followed a song on LP with the same song on CD. I believe it was the inherent noise platform on vinyl, the noise you hear on the lead in grooves and between songs. Yet I never really heard that noise once the record was playing. Perhaps it adds a sense of "fullness" whatever that is. It may be the same with partially heard frequencies...
  16. bluesky
    bluesky Addicted Member
    7,641
    Read an article in AARP last month, or this month, on Tinnitus. Nothing can be done.
    :dunno:
  17. triode17
    triode17 Super Member
    1,380
    You must be cautious with Audiology. Unless things have changed since the 90's when I last had tests done, they only check for the intelligibility frequencies, from 300Hz-8kHz. That leaves us a bit short.
  18. crouse
    crouse Poorly known member Subscriber
    1,393
    Jackson, Ms.
    That chart indicates that someone whose hearing is kaput above 5khz can still hear the harmonics of most instruments. Which goes a long way to explaining why I still enjoy listening to music.
  19. Bodyblue
    3,839
    CA
    Yeah, Drs are clueless. Are you going to claim anything else that has no basis in fact?
  20. hugo454
    hugo454 Gold Member Subscriber
    1,597
    south florida
    What?,I can't hear you.
