well, its 6AV6 tubes. Those 6 make up 3 12AX7's. TO guess at it, its got two wired as a gain stage, and one as a cathode follower per channel. 6AV6's are pretty cheap though, so its not a bad tube to use for this if you've got chassis space and power supply capacity.
What I don't fully get are the other set. 6X4 is the rectifier, so B+. 0A2 is a voltage regulator, and a 6AQ5 is a beam pentode. I'm guessing they are using the 0A2 as a reference voltage to drive the 6AQ5 in a voltage regulator configuration ? Whats the other one?
