Legrace
Super Member
About a year ago hooked up with a new girl, got nice tubes. But there are things I like about my SS girl too. Why not enjoy both, ie biamping!
Speakers are Tannoy D700's. 2 x 10" driver, upper one is a dual concentric driver incorporating a tweeter at its center, something Tannoy are known for. Bottom taps are connected to VTA 125 tube monoblocks, and a Marantz PM11S1 handles the upper registers. Latter also serving as control amp.
As I prefer to run the monoblocks in triode mode biamping the high end with the SS amp helps address the issue of high end softness with tubes operating in triode mode. ie preserves upper end sparkle. Tucked in behind the left Tannoy is a 500w 12" sub. Using its 80 hz hipass filter to pass only 80 hz and above to the Tannoys. Triode mode slices power output in half to 60 w/monoblock, so need to be judicious with those watts!
Deck is a Rega w/AudioMods V tonearm. Feeding into a Sutherland Phd phono pre which is a battery based design, 16 x D cells. Very silent unit. IC's are Siltech 330i silver/au alloy for phono signal and Siltech 180i copper elsewhere.
Many enjoyable hours spent with this setup! Pics:
