Dave918
Super Member
First let me say that I’m not a technical person when it comes to audio components, especially amplifiers and most especially tube amplifiers. Want a high-speed data network? I’m your guy. But I’m as lost as fart in a whirlwind on this stuff. I’m just a guy who loves good music that wants an audio system that reproduces music in a way that’s pleasing to my ears. So, keep in mind that this review is from a layman’s point of view. That said, let’s take a look at this feller.
First off the AQ-1001 DT is a KT-88 based tube integrated amplifier with selectable ultra linear (2x50wpc) and triode (2x25wpc) modes of operation (what did I say? and did I say correctly?). It’s a larger unit than I expected at 16.25” wide x 12” deep and weighs in at a respectable 50lbs. The chassis is made from heavy gauge aluminum and steel with a brushed finish. All transformers are enclosed in black finished metal covers.
The front panel has a very simple layout with a power switch, power indicator, level and input selector pots. The rear panel has inputs for CD, Tuner and AUX, a sub-woofer output and speaker connections for 8 and 4 ohm loads. The AC power connector is also located on the rear panel.
The top of the amp features a very neat and orderly layout. At front center is the tube bias meter with the bias adjustment tube selector pot (love that built-in bias adjustment) and ultra linear/triode switch. A row of 4 12AU7 input tubes follow, with the 4 KT-88 output tubes separated by a choke transformer (huh?) just behind. Located behind each KT-88 is a bias adjustment pot. The 2 output transformers and the single power transformer are located across the back of the top plate.
Overall this is a gorgeous amp with excellent build quality. Now, how does it sound?
The AQ-1001 has a very warm, inviting sound while providing incredible dynamics. Combined with the Reynaud Twin MKIII’s and Jolida JD100A CDP, the synergy is simply breathtaking. I spent a considerable amount of time evaluating the sound and performance of both operating modes and finally settled on Triode as my primary preference. It just simply provides a warmer, smoother sound and the efficiency of the Reynaud Twin MKIII’s easily minimizes the reduction in power. The soundstage is wide and deep as is the bass performance. Midrange is strong and upfront, and the high-end is quite simply the best – matches my tastes dead on.
The AQ-1001 DT is certainly a winner and has completely sold me on tubes. Am I giving up on solid-state? Nope, but I will be thinning out the herd a bit (I say that – then go and agree to buy a Cambridge A500 this morning. Damn this disease!). It’s hard to believe that this amp could sound any better than it does with the stock tubes, but I’m told that it certainly can. My plan is to continue to use the stock tubes for a while longer as I learn more about the technology – and then take a look at doing some tube rolling. It doesn’t get any better than this guys – at least not until the next piece of gear comes along.
My thanks to Brian over at Venus Hi-Fi for matching me up with this amp, and the complete system as well. Thanks Brian!
System:
Antique Sound Lab AQ1001 DT Integrated Tube Amp
Jolida JD 100A Tube CDP
Jean-Marie Reynaud Twin MKIII Loudspeakers
Cables:
Speaker: Monster XP Clear, tinned ends, un-terminated
Interconnects: Dayton Audio Analogue RCA, 1.5m
Power Cables: Stock
Note: Just recently added a Blue Circle BC86 MKIII Powerline Power Filter. Check out my review of this device http://audiokarma.org/forums/showthread.php?s=&threadid=11325
CD’s used for evaluation (all redbook):
Patti Austin “For Ella”
Diana Krall “Live In Paris”
Sara McLachlan “Mirrorball”
John Hiatt “Slow Turning”
Robben Ford “Robben Ford And The Blue Line”
Steely Dan “Aja”
Alison Krauss “Forget About It”
Elvis Costello “My Aim Is True”
Bob Dylan “Blonde on Blonde”
Links to other threads where this system has been discussed:
http://audiokarma.org/forums/showthread.php?s=&threadid=9823&perpage=40&pagenumber=1
http://audiokarma.org/forums/showthread.php?s=&threadid=10875
Specifications:
Output Power: 50Wx 2 Ultra linear, 25Wx2 Triode
Frequency responsible at 1W: 15Hz - 23KHz
Distortion at 1W: < 0.1%
Distortion at full power: < 3%
Frequency responsible at full power: 23Hz - 24KHz
S/N Ratio / Noise level mV: 83db /1.8mV
S/N Ratio with A weighting: 95db (0.7mV)
Input impedance: 100K
Output Impedance: 8, 16 ohm
Input sensitivity: 400mV
Power request: 340W
Fuse: 5A Slow blow
Power cord - Detachable
Input Sockets: RCA Gold Plate
Output terminal: 5 Way Gold Plate Heavy duty
Tube Complement: KT88 x 4, 12AU7 x 4
Antique Sounds Labs
web address: http://www.divertech.com/antiquesl.html
Venus Hi-Fi: http://www.venushifi.com/
Check out the “Members Gallery” for photos.
System:
Cables:
Power Cables: Stock
Steely Dan “Aja”
Specifications:
Power request: 340W
Fuse: 5A Slow blow
Antique Sounds Labs
