I have to agree with this. You could bi-amp the K7.2's using the built-in passive crossover. Triamping would necessitate an active crossover. I agree with swechsler, I don't think there would be much benefit to using separate amps on the mids and EMITs.Seems unlikely; tweeters don't use much power. Even in their most expensive systems (IRS series), Infinity has never done triamping.
Interesting. What kind of Infinities do you have, what are you using for amps and crossover, and what sort of improvements did you hear when going from biamping to triamping?
I agree wholeheartedly. Sure it's a bit of a pain, but phase correct 24 dB slopes, the ease of fine tuning, getting rid of lossy passive components (especially big woofer coils) definitely make it worth it. There's a reason pros haven't used passive crossovers for decades.I bi-amped infinities for > 35 years. In the last year, I've gone to tri-amping. Actually, 4 amps if you want to count the self powered infinity subs. If they were not self powered, I'd be buying another amp to drive them.
Yes it does sound better. No doubt about it. But the costs are high with the crossover and the amps. They are far far more than the speakers cost. Then you have to factor in speaker cables. Interconnects. Power cables. Quite an investment we are talking about.
To me, it was worth it.
I would not recommend hooking up direct to the emims and emit's, if any dc will wipe out your drivers
