Speakers : Front - Infinity RSIIIa, Rear - Infinity RS5b, center - currently a JBL Studio Series/S-Series, sub - (doesn't matter, separate amp)
Receiver: Onkyo TX NR646
I know, try it and see...I will.
Just asking for opinions before I move a bunch of speakers around. Just some general BS, nothing serious.
The receiver has run everything from Klipsch Chorus II's to AR3a's in stereo, and sound just fine. The Klipsch and KLH 5's sound nice as surround mains. I know there's a lot more to multi-channel amps.
All channels simultaneously driven at what power, and does that question even matter?
Speaker Impedance - 6 ohms to 16 ohms (does that mean 6 ohms per speaker [1.2 ohms])
Amplifier Section
Power Output
All Channels 170 W/Ch (6 Ohms, 1 kHz, 0.9% THD, 1 Channel Driven, FTC);
100 W/Ch (8 Ohms, 20 Hz–20 kHz, 0.08% THD, 2 Channels Driven, FTC)
Dynamic Power 240 W (3 Ohms, Front)
210 W (4 Ohms, Front)
120 W (8 Ohms, Front)
THD+N (Total Harmonic Distortion + Noise) 0.08% (20 Hz-20 kHz, Half power)
Damping Factor 60 (Front, 1 kHz, 8 Ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
3.5 mV/47 k-ohms (Phono MM)
Rated RCA Output Level and Impedance 100 mV/2.2 k-ohms (Zone 2 Line Out)
200 mV/470 Ohms (Subwoofer Pre Out)
Maximum RCA Output Level and Impedance 1.0 V/2.2 k-ohms (Zone 2 Line Out)
2.0 V/470 Ohms (Subwoofer Pre Out)
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 10 Hz-100 kHz/+1 dB, -3 dB (Direct Mode)
Tone Control ±10 dB, 20 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 100 dB (Line, IHF-A)
80 dB (Phono MM, IHF-A)
Speaker Impedance 6 Ohms–16 Ohms
Amplifier Section
Power Output
