Yep it's butyl covered cloth. Plus, the roll on these is toward you, while the roll on most KLH's is the opposite way. And it's leaking some, whether thru the surround or thru the old sealing mortite or the box joint seals. You can get a tube of Silicone joint sealer and do the box joint seals, let it cure overnight, then refill the box with the stuffing, and seal the drivers to the box with the plumber's putty. When you press on one that's sealed correctly it should show some resistance. It sounds like yours isn't. It should be somewhat stiff, but not as stiff as a paper edge cone, and a little looser than a speaker designed for ported use. The box, when sealed correctly is used as part of the suspension to limit travel of the cone, so it'll feel a little mushy compared to a speaker in a ported box.
