Anybody know where I can get a good 2 channel 15 IPS reel to reel tape deck?
Discussion in 'Tape' started by KaatheSnake, Jul 25, 2018.
  1. KaatheSnake
    KaatheSnake Well-Known Member
    614
    Auburn, Alabama
    Hi everyone,
    I'm looking for a good 2 channel tape deck that runs at 15 IPS I can use for mixing down and mastering four channel recordings made on my TEAC A3340S down to a 15 IPS 2 channel master. I have a 16 channel Electro Voice mixing board, and all the stuff I need to master with, but not a deck I can make the "master tape" with. I've searched on eBay, and found some stuff I'm thinking I like there. What kind of 2 channel 15 IPS deck would you recommend for mastering use is what I'm asking for in the long run.
    Kind regards and thank you,
    KaatheSnake
  2. jcamero
    jcamero If you get confused just listen to the music play Subscriber
    3,786
    The Bright Side of Life
  3. wlhd1610
    wlhd1610 Penny and her new friend Sponsor Subscriber
    2,362
    Catskill NY
    Teac 3300SX 2T?
    Bob
  4. KaatheSnake
    614
    Auburn, Alabama
    I'll try that one.
  5. revox-b77
    revox-b77 AK Subscriber Subscriber
    2,877
    Fingerlakes, NY
    Otari 5050MX
    nh36000, KaatheSnake and bajaed like this.
  6. revox-b77
    2,877
    Fingerlakes, NY
    Revox B77
    KaatheSnake likes this.
  7. sixthday
    sixthday Super Member
    1,199
    Otari 5050MX is good
    nh36000 and bajaed like this.
  8. Chip Chester
    Chip Chester Super Member
    1,941
    Central Ohio
    nh36000, revox-b77 and KaatheSnake like this.
  9. mhardy6647
    52,157
    Good and readily available -- although condition varies greatly in the wild.
    Many of these were radio station machines and as such were rode hard and put away wet. (as some folks would say)
    http://tapeproject.com/machines/
    My half-track high-speed A77 is a very good performer, but the A77 is a bit idiosyncratic.
    There is someone now doing essentially "new" rehabbed vintage decks. Pricey but a good option.
    I can't remember the name but will update here if I do manage to find it.
  10. mhardy6647
    52,157
    The A80 is a fine machine. Any that hasn't been rehabbed will need a fair amount of TLC, though. I say this knowing one of the local hifi gurus who's been working on getting his up to snuff for a long time.
    EDIT: This may be what I was thinking of:
    http://www.unitedhomeproducts.com/reel_to_reel_hq_tape_decks.htm
    (but there may still be another resource that's still escaping me)
    EDIT^2: Naah. It was these guys I was trying to remember:
    http://maramachines.com/
  11. edwyun
    edwyun Super Member
    1,167
    NY/NJ, USA
    Particularly the MX5050 BIII. Another option is the MX55N. :)
    nh36000 and KaatheSnake like this.
  12. KaatheSnake
    614
    Auburn, Alabama
    I'll try an Otari. I'll get some good mastering quality out of it.
    nh36000 likes this.
  13. KaatheSnake
    614
    Auburn, Alabama
    Pretty sure the Revox B77 is a 3 3/4 and 7 1/2 IPS recorder.
  14. KaatheSnake
    614
    Auburn, Alabama
  15. edwyun
    edwyun Super Member
    1,167
    NY/NJ, USA
    The MX55N handles tape better than the MX5050, even though the former is an older model. Plus, in a pinch, you can record at 30ips :)
    But as already noted, many were run hard. Not that they couldn't handle such abuse but the heads/guides, etc., may need to be restored. Figure a few hundred for a full service from a well known tech.
    Also look for Otaris with the 2/4 heads. They can record 2-track but play 2-track and 4-track.
    sdw54 and KaatheSnake like this.
  16. KaatheSnake
    614
    Auburn, Alabama
    I don't buy heavily used tape decks. My TEAC A3340S I just got was NIB, recapped, calibrated, oiled, and mechanically repaired. The machine doesn't have a single scratch, dent, chip, or fingerprint on it. I just need a deck I can transfer my quad multitrack recordings down to a 2 channel stereo master. I would like a 15 IPS machine, and 30 IPS would be very nice. The heads on the A3340S were tested for frequency response, and here's how they rated: 20Hz-24kHz at 15 IPS, and 25Hz-20kHz at 7 1/2 IPS. That's exceptionally good sound!
  17. rojoknox
    rojoknox Member
    80
    Gresham OR
    Greetings from RojoLand!
    Many were (mine is). But B77s were made with different speed combinations (as well as in 2-track and 4-track). The HS (high-speed) version runs at 15 and 7-1/2 IPS. A slow-speed version (1-7/8—3-3/4) and slower-speed version (15/16—1-7/8, for radio-station logging etc.) were also made.
    I have a Tandberg 10X two-track which runs at 3-3/4, 7-1/2 and 15 IPS (does a nice job, too). But I don't think I'd recommend one to you, since they can be a bit fussy, and parts aren't common. I recapped mine (which was given to me).
    Others have suggested a Teac A-3300SX-2T. Second that, though I don't have one. Teacs are high on my list. I do have a quarter-track A-6300, and would also recommend its cousin the A-6100 which is 2-track, runs 15—7-1/2, and also has a quarter-track playback head so you can play either type. (Records only two-track.) My A-6300 is the only one of my decks that can truly make a 3-3/4-IPS pre-recorded tape sound good (and it isn't even recapped yet).
    Take care,
    J. E. Knox "The Victor Freak"
  18. KaatheSnake
    614
    Auburn, Alabama
    Thank you for the advice! What about a TEAC A-7030?
  19. rojoknox
    rojoknox Member
    80
    Gresham OR
    A Teac A-7030 is similar in function to an A-6100 but is several years older. Take that into consideration. Older electronics will definitely require recapping, may have older type transistors which will be harder to replace. (I'm starting a recap of my 1967-vintage A-4010S; it's full of PNP germanium transistors that were obsolete almost right out of the box.) Older Teacs are also more likely to have Suzuki oil-type capacitors used as switch/relay/solenoid snubbers, and they like to fail short and go BANG! MUST be replaced.
    I found this page on the A-7030: http://stereonomono.blogspot.com/2012/01/teac-7030.html
    Take care,
  20. KaatheSnake
    614
    Auburn, Alabama
    Okay. I'll see if I can get one.
