Hey lifer70
Thanks for the info and I'll check and see if the cbles come with it.
I picked one up a few months ago. Disappointed that all of the front panel lights were out. So i bought red and green LED replacement bulbs on ebay, very nice replacementl. (recommend amber for start and green for all clear). When I opened it up to replace the bulbes? I noticed half them were fine. One broken fingernail later, after flicking the center solenoid a few times? the bulbs worked again. An hour of soldering later? all the bulbs replaced with LEDs and it looks awesome. I was told by a repair tech that the LED bulbs would be too bright, but the ones I found on ebay are absolutely perfect. I would put this up against McIntosh amps any day of the week. DC offset when I measured it is well below 2vdc per channel. And just an FYI, this is NOT the same as the m-504. It has 8 matched output transistors (instead of 4), 88,000mfd power supply caps (instead of 72,000), damping factor of 180 (instead of 140) and THD rated at .002%, (compare to .003%). Subtle, but noticeable differences.
I bought these, http://www.ebay.com/itm/282182508515, and the matching red (Originally white for relay on, green for all okay). For me? the amount of light is perfect. Can't tell if on during the day, a bit of a soft green light at night. And FYI, you should replace all of them at once. Incandescent and LED don't play well together on the same circuit or so I've been told. It's worth it to replace all of the bulbs at once. Saves you taking it apart again later. Normally the incandescent bulbs will last between 2-3000 hours while the LED's should last 100,000 or more. Also, make sure the LEDs are facing "down" towards the meters. (yes, 4 safety relay on, 4 normal power).
Thanks for the help. I had a M-504 before and I always regretted selling it; I don't think it has the amber lights like the M-506RS has because I did have to replace the bulbs once and I only saw four green bulbs. I actually like the green better than the blue so I ordered 4 green LED replacements not realizing that there were also 4 amber bulbs that need replacing so I ordered 4 more red LEDs as I didn't see any amber LEDs on Ebay.I replaced mine with blue LEDs. I didn’t like the green. The amber lights are only on during power up, while the amp checks to make sure everything‘s OK before throwing the main relays.
There were two Amber bulbs in each meter.
