Anyone using a Denon DL-103 with their C-2a, C-4, C-6 preamp?
lowredmoon
I've read some posts by people who are using a DL-103 (40 ohms output impedance) with their Yamaha preamp (50 ohms MC input impedance), but without much dialog on the result. I know that on paper, the DL-103R (14 ohms output impedance), which costs almost twice as much better matches the published Yamaha spec, but if you have tried the DL-103 with a Yamaha preamp, I would appreciate hearing your results.
Thank you!
Adam
I’ve used a DL-103 with my C-2x at 100ohms and it sounds quite good. 100ohms (or higher) is the recommended setting for the DL-103 from Denon.
