Anyone using the D1100 as their only preamp?
Discussion in 'McIntosh Audio' started by joeinid, Nov 14, 2017.
  1. joeinid
    joeinid AK Subscriber Subscriber
    765
    NY
    All the reviews, past a couple of hiccups, are really, really good.
  2. ron-c
    ron-c AK Subscriber Subscriber
    8,167
    N. Ca.
    I have at a few shows and it sounds fantastic. Usually combined with MP1100 and MT5 or MT10, MEN220, Win computer, a couple of big amps, and MCT450. Have also used it as a DAC slaved to C1100 and this works great too.
    Thanks,
    Ron-C
    joeinid likes this.
  3. 4-2-7
    24,300
    San Francisco Peninsula
    I do find it interesting you use the MEN220 constantly in your setups, I do know your rooms are all different so it must help a lot.
    I'm wondering how practical it would be in ones home where the room doesn't change.
    Even so I do swap out speakers and or switch speakers to different amps.
  4. 'cisco
    'cisco Well-Known Member
    894
    808/415
    As a pre.....I've tried it with my MDA 1K and with my DAC in my C47 but I couldn't get it to work with my LED TV via optical cable....I need a analog (rca) connection to
    make it happen. I was getting a dump,dump dump noise thru my speakers. If anyone has any ideas on connecting a TV to a MDA or possibly a D1100...I'm open?
    I would also be interested in acquiring a D1100 to upgrade my MDA if that would be my only option. :)
  5. JMezz
    JMezz New Member
    2
    Long Beach, CA
    I had a similar issue with a C2500. The key is to make sure the TV is sending a PCM signal to the DAC.
    ron-c likes this.
  6. kevzep
    Well I have a MEN220, wouldn't be without it. Of course the room doesn't change, so all that means is its only set up once.
    Not sure I understand what you mean by "how practical it would be in ones home where the room doesn't change."
    If I was doing what RonC does, I would use one too.
    They do more than just room perfect.......
    Velocityboat and ron-c like this.
  7. Dr Tone
    Dr Tone Active Member
    258
    Calgary, AB
    As JMezz indicated I run TV into my C47 optical with the TV set to send stereo PCM. Make sure to use the second optical input instead of the first if also using USB as the C47 has a flaw with the USB input sound still coming through when choosing the first optical input.
    ron-c likes this.
  8. 'cisco
    894
    808/415
    Thanks JMezz and Dr.Tone.....I'll see what I can do to make it work.
  9. Velocityboat
    Velocityboat Well-Known Member
    949
    TX
    If he is swapping speakers and amps the Room Perfect woul need to be rerun each time. The latest Lyngdorf integrated allows two separate RoomPerfect speaker calibrations. I don’t think MEN220 allows that. But recalibration goes quickly after you get the hang of it.
