Apple is Diabolical. The Bluetooth earphone Cartel
Discussion in 'Digital Sources' started by transmaster, Feb 13, 2018.
  1. transmaster
    transmaster AK Subscriber Subscriber
    8,596
    Cheyenne, Wyoming
    It was once a search for the best sounding earphones for my iPhones, for me that is the Etymotic hf3. Now it being held hostage by batteries. Used to be cable failures now it is batteries failing to charge. I love the necklace design for earphones. What I would love to see is one that you could use AAA batteries. Except for the connected Klipsch Neckless all of the others are draped over my desk lamps with charging cables plugged in.
    Here is what Apple has done to me.
  2. transmaster
    8,596
    Cheyenne, Wyoming
    What would be great wireless charging earphones, just drop them into a charging bowl like gum drops.
    faber12 likes this.
  3. Dswankey
    Dswankey Super Member
    3,925
    I'm confused, what does Apple have to do the Etymotic hf3? also what do you mean by "it being held hostage by batteries.....now it is batteries failing to charge "?
    slimecity likes this.
  4. transmaster
    8,596
    Cheyenne, Wyoming
    Starting with the I phone 7 there is no 3.5mm phone plug. So instead of cables failing it is now batteries.
    KentTeffeteller likes this.
  5. ictwoody
    ictwoody I like vintage gear — my preamp is from 2007. Subscriber
    2,694
    Wichita, Kansas
    Use the dongle. Or get a pair of lightning headphones. I have a pair of Noble Audios which I love that use lightning. For less money the 1-More Triple Drivers are good, though not as neutral.
    -Woody
  6. uofmtiger
    uofmtiger Super Member
    4,893
    Memphis
    If they were doing their job, you would have AirPods on that list. They even provide a dental floss case to charge them. Nope, this is all on you.:p
  7. Dswankey
    3,925
    I'm kinda confused, the title of your post is "Apple is Diabolical. The Bluetooth earphone Cartel"
    Are you inferring it's Apple causing the batteries to fail?
  8. faber12
    faber12 Super Member
    4,155
    Northwest Ohio
    Is there a lightning to 3.5mm adapter available?
  9. KentTeffeteller
    26,145
    Athens, TN
    A: Bluetooth will never be as good as wired. B: This is also a freedom of choice matter. for many of us sound quality is important. C: These charging issues for those who want to use better options and where battery charging becomes a problem.
  10. uofmtiger
    4,893
    Memphis
    Yes they were including an adapter in the box alongside a pair of lightning earbuds.
    That being said, unless you have a dock or adapter (you buy yourself), you can't charge and play them at the same time.
