Yes. But you adjust them identically, and do the math to get the optimum output. Watts is Watts. Higher voltage will equate to a higher current on the cathode , hence a lower(more negative) pin 6 voltage on the "C".
800B output
800c Output.
The numbers for pins 6 on the "B" and "C" are based on maximum dissipation of 19W for the 7591. Optimally for longer life of the tube (less stress, etc) we won't run them flat out. especially the russian tubes. So an operational envelope of 70% to 80% of maximum dissipation is recommended for all tubes. You can run them higher than 80% if you have $$$ burning holes in your pockets, which in addition to killing the tubes also puts undo stress on the caps and resistors from the P.I. to the outputs.
You want say for example 75% of max dissipation on the 7591 which is 19W.
The following are Examples based on schematic values. Your voltages will undoubtedly be different for the plate and screen voltages. Ideally you want to run the 7591 between 70% and 80% of maximum dissipation. 70% is 13.3w and 80% is 15.2w 75% is a good medium value of 14.25W
After getting the initial ma, subtract 3 ma for screen dissipation. (So bump the ma by 3 ma to compensate).
75% of 19 is 14.25W. On the "C" model divide 430v by 14.25w and you get 30.175ma. This is your cathode draw in ma that you would get for 75% on the "C". Now subtract 3ma for screen dissipation. the ma is now 27.175 and wattage is 11.61w so bump the ma up to 33 to compensate for screen dissipation.
Your actual wattage with screen dissipation is actually 14.25W.
On the "B" divide 393v by 14.25w and you get 27.57 ma. The same applies for the "B" as the "C". Add 3 ma to 27.5 to compensate for screen dissipation.
As the plate goes up you need more cathode current to make 14.25W. Conversely as the plate voltage goes down, you need less to make 75%
FOR EXAMPLE on my Sansui 1000A (which is essentially a Jap 800c) The plate Voltage is 480V. I run them at 75 % so we'll use 75% to be consistant. 480 divided by 14.25 = 33.68ma add 3ma to compensate for screen dissipation and you have a cathode draw reading of 36.7(rounded up.).
You get the same wattage at different plate voltages with different bias voltages and ma's. The output wattage is the same! Ohms LAW at Work.
