    Dismiss Notice
Are there any speakers with ports on the sides instead of front or rear?
Discussion in 'Speakers' started by toxcrusadr, Jun 11, 2018.
  1. toxcrusadr
    32,818
    Central Missouri
    Just got to thinking about this in relation to a speaker building project. One problem with rear-ported speakers is you can't shove them back against a wall, which many listeners have to do because of room limitations.
    There are certainly speakers with side mounted woofers...the AR9 for example. Why not side-mounted ports?
    I can't think of a reason this wouldn't work. Theoretically you can put the port anywhere you want, right?
    So why haven't I seen one like that? :idea:
  2. Porkloin
    Porkloin Oscar Heil Groupie
    2,881
    Kent, WA
    It's got to be a marketing/logistical/aesthetics thing. Manufacturers didn't want a bunch of old audiophiles calling down there asking for "mirrored" port layouts.
    imral3 likes this.
  3. 45rpmspinner
    45rpmspinner AK Subscriber Subscriber
    Yep.
    Although I think some rear port designs are meant to boost bass via wall bounce...which I tend to think only muddies the sound.
    Side mounted passive radiators are common enough.
    I don't see a problem.
  4. hjames
    hjames dancing madly backwards ... Staff Member Moderator Subscriber
    12,219
    VA near DC
    I had a JBL L60T years back. Used a hole sawl to drill a new hole in the front and moved the port tube from the back to the front panel ...
    Glued the hole saw "plug" into the old rear hole to finish the job.There may be phasing issues moving a port from back to front -
    but putting one on the bottom or sides is a deeper challenge one would think.
    Physically easy, of course.
  5. toxcrusadr
    32,818
    Central Missouri
    Well if I'm building them from scratch the mirror image layout shouldn't be a problem. I hadn't considered that as a reason you don't seem them commercially.
    This is a big line array with the old Pioneer NSB drivers (which I've discussed here before but haven't built). It would require (4) 6" dia. ports so I could put two on each side if I wanted.
  6. mike j
    mike j Too many hobbies Subscriber
    381
    Hartland, CT
    My Vortex Screens have side-ports, and mirror imaged too.
    nexus likes this.
  7. CopperWizard
    CopperWizard Well-Known Member
    832
    Eugene, OR
    That gives me an idea for ports front, back and mirrored sides. Then a kind of port plug to seal off the unused ports. Gives options further down the road, different house, different furniture, walls. Or not.
  8. toxcrusadr
    32,818
    Central Missouri
    Cool idea. Like a refrigerator where you can switch the door opening direction.
  9. toxcrusadr
    32,818
    Central Missouri
    If only we could make beer come out of the speakers, then we'd really have something.
  10. donprice
    donprice Wound up workin' at a gas station.... Subscriber
    2,376
    JBL B460 subwoofer has the ports on the side.
    hjames likes this.
  11. TOM1040
    TOM1040 Well-Known Member
    582
    Coast of Maine
    I think the Klipsch P-39F Palladium speakers are built with ports on the side.....
  12. x3workshop
    x3workshop AK Subscriber Subscriber
    1,980
    Harlem
    My Rega R7s have side ports. Mirrored.
  13. toxcrusadr
    32,818
    Central Missouri
    Great to see so many examples. AK never fails with the info. :thumbsup:
  14. toddalin
    toddalin Super Member
    2,318
    JBL B460 has side ports.
    nexus and Ds2000 like this.
  15. bimasta
    bimasta Super Member
    2,566
    Even if there are no sonic benefits, it makes them much easier to carry...
    faber12 likes this.
  16. 3db
    3db Active Member
    168
    My PSB Image B15s are fronted ported. I had a pair of Technics SB-T200 which were ported in front and back.
  17. toxcrusadr
    32,818
    Central Missouri
    Not a JBL expert but I definitely pay attention and I don't think I've seen this beast before. Cool.
  18. CT_Ohio
    CT_Ohio Active Member
    354
    Ohio
    Dunno about commercial ones, but I asked a similar question a few months ago re: my home build. In that case, I put the ports on the back as I don't have a grille to cover them up on the front, and case seemed too small for bass tube on the side.
    http://audiokarma.org/forums/index.php?threads/bass-port-front-back-or-side.812662/
  19. faber12
    faber12 AK Subscriber Subscriber
    4,029
    Northwest Ohio
    DJ/pro/PA speakers have handles and such, would it kill the home speaker mfrs to give us a little something to safely lift their offerings?
  20. 3db
    3db Active Member
    168
    Maybe but it will raise the WAF to the fore front. Thats a battle I rather avoid.
