Okay thanks,my brother is likely getting them tomorrow.
Hopefully they are 2's.
From research online it looks like they switched to rubber surrounds in model ci,hope they don't have foam.
Well my brother finally picked them up.
They are Model 1's.
No stands,he didn't talk to the owner when he picked them up so there is a slight chance that he has them.
One bottom has some slight water damage,other then that they look fantastic.
From info online the (C) version will be marked with the letter after the serial #,these are not,can anyone confirm that all C's would be marked this way?
Also,while TRYING to shine a light through the cloth it looks like they have THIS tweeter.
IF i'm understanding correctly that could make them b's.
Can you see through the grills to see the woofer surrounds?
You can play them at low volume without fear of damage (I assume that your definition of low volume is not that far from mine). If you are really worried, play them face up (or on risers face down). That's tell you if the drivers work, and might tell you if the foam is bad, or getting there
