Not to be snarky- but I've seen and heard his TOTL PS Audio amps, and I've also seen and heard the TOTL VAC tube amps. Guess which ones pretty much everyone thought sounded better?
The one thing that these talks don't mention- is that a good single vacuum tube, is far more linear of a stand-alone amplifying device, than any single transistor.That's just a simple fact. Just look at the conductance curves... the lines are far straighter, and more evenly spaced, on good tubes (such as KT88s, 6DJ8s, 12B4s and such).
From my observances over the last decades of working with amps of all types- the only real reason transistor amps sound as good as they do, is that transistors are cheap enough that you can use LOTS OF them- either with some of them acting to make it possible to correct the errors in the rest (high levels of open-loop gain- which facilitates high levels of negatve feedback, which has its own issues), or with lots of them arranged as in some sort of high-power digital-to-analog converter or something analogous to that (which also has its own issues- filtering, harmonics, and such). Tubes need no such complexity...
That said- transistors can act to improve tube amps. The most evident example of that, IMHO, is the iQ Auto Bias circuit used in VAC amps. It's basically a processor- based on transistors- that keeps the idle current stable in all the output tubes, regardless of tube age, condition (within reason- if the tube is totally worn out or broken, it will just tell you to change the tube, though), or the signal going through the amp. That wouldn't be possible without semiconductors...
Regards,
Gordon.
