I have tried that but even on the SL-1200 with 52mm overhang its too long to keep the strain off the cartridge so it bends messing up VTA.You can also use a P mount 1/2 " adapter. Then it can be mounted on any arm.
It was never used and everything is in mint condition but it's not a popular model so I doubt people are looking for it. Also P mount decks are kinda hard to find apart some of the high end Denons.I suspect the cantilever's been stiffened a bit by heat treatment, too, though I have nothing to back this hunch up except the appearance of the cantilever. It's a good stylus, it's not widely known because of all the sub-brands and different colors, and it sounds very good. Worth pursuing.
The dual oval means its a bonded elliptical. A nude should be a single oval.I bought an AT 450 back in the early 90s at Good Guys. It was $79.99, and I still have the cart and packaging. The original stylus is long gone - it went out on a craigslist table I sold years ago. The label on the box says "AT 450 0.3 x 0.7 mil Nude BiRadial".
It sounded great back then. The stylus on my cart now is white, and has the same clear oval symbol with another solid oval inside of it. I have no idea what that means, but it was a cheap replacement I bought years ago, and no longer use.
(...) I have the cart mounted with 1/2" adapter on a TD166 Mk2 with TP11 Mk2 arm (...)
Good choice. On quite a few Thorens tables with Thorens arms, the latter are high enough to accomodate pretty tall cartridges (including T4P/P-mount carts in halfinch-mount adaptor, which typically are ca. 20 mm) without the cart/needle bottom to record surface clearance problems ChefE described above - and of course the light Isotrack arm versions also fit well to the typically pretty high to high compliance of T4P/P-mount carts or respectively needles.
Greetings from Munich!
Manfred / lini
(...) These screws are thinner than regular head-shell screws (...)
