p4spooky
Sansui Experts: Found a bargain on AU 317 few weeks ago - got it free along with TU217 tuner
Ordered parts from Mouser following some great threads here. I will be posting pictures of the work done along with some changes I made. The good news is the AMP is working great!
I noticed F-2754 board does run warm (about 54 deg C - Lower right corner below the Phono board) after couple of hours of use around the area where C03, C04, C09, C10 is located next to the 18v Zeners. I currently have used 33uF 50V Silmic II caps (85 Deg C) as replacement. Appears to be an incorrect choice now that I am looking at the schematic closely and the temps in this location.
Also can someone explain what this cap does parallel to the 18v Zener? Can I replace this cap with 100uF 63v UHE or equivalent? Please see attached schematic.
