au-505 rectifier substitute
Discussion in 'Exclusively Sansui' started by petehall347, Jun 12, 2012.
  1. petehall347
    28,343
    uk.. the middle bit
    rectifier fitted is IR 10dc1 .its dead short so i was thinking 2x 1n4007 to replace it.
    any reason why not ?
  2. Hyperion
    49,904
    Hertfordshire, UK
    I can only find an NTE equivalent data not the original.... 600v, 1A rectifier? :idea:
    One 1N4007 should be enough....? (1N4007 = 1000v, 1A)
    (I would have thought 10DC1 would be a 100v, 1A rectifier - but I can't find a data sheet)
  3. petehall347
    28,343
    uk.. the middle bit
    the 10dc1 that came out has 3 legs . 2 for ac one for dc .so its sorta half wave rectified using a double diode . the 10dc1 is rated at 1amp .i fired it up with 2 1n4001.s and it seems to work ok . i just thought for good measure use the 1n4007,s
  4. Stene
    Stene The Introducer
    2,200
    Stockholm Sweden
    According to a Technical Manual from Sansui
    10DC-1 (black)
    VRM 100
    Io 1.8
    Center tap +
    10DC-1R (red)
    Center tap -
  5. Hyperion
    49,904
    Hertfordshire, UK
    Aha, in that case you will need at least a pair of 1N4002's (=100v VRRM) as 1N4001 is only 50v VRRM - as I you know a pair of 1N4007 will do just as well. (got there in the end - :))
  6. petehall347
    28,343
    uk.. the middle bit
    cheers
    1n4007 are now ordered
  7. petehall347
    28,343
    uk.. the middle bit
    righto if anyone else reads this in the future the 2 1n4007 diodes work well instead of the original dual diode .
    i could of course installed a modern dual diode rectifier but this way is much cheaper .
    plus there are holes already in the board for the 2 positive ends of the diodes .
  8. toscanob
    toscanob New Member
    Thanks, guys from the past. LOL
    petehall347 likes this.
  9. AcerPalmatum
    AcerPalmatum New Member
    15
    The thread that keeps on giving. I just replaced a 10dc1 with 2x 1n4007. It seems to be holding up well
  10. dapbmw
    dapbmw New Member
    18
    Hello so where do you put the the 2 wire newer style diodes as the old ones have 3 legs, sorry not technically inclined, if you can post photos, I would appreciate it. :)
  11. Hyperion
    49,904
    Hertfordshire, UK
    The original seems to be an encapsulated pair of rectifier diodes, the device has 3 legs, and often the internal arrangement is printed or moulded into the case.
    It should look like this AC ~ ----I>I----I----I<I---- ~ AC - a connection at each end for AC from the transformer, and the centre connection is the 'DC out' connection, 3 connections in all.
    Your replacement rectifier diodes look like this ----I>I---- ----I<I---- there should be a band or mark on them to indicate polarity - I have marked where the bands should be with a bold line, like this ' I ' - join the 2 banded ends together - this is the DC out connection, the other ends of the rectifier diodes are the AC inputs, 3 connections in all.
    Get yourself a copy of the Service Manual and take a look at the schematic diagram - all of this should then be a lot clearer to you. ;)
    Post #5 in this thread shows the 3 connections to the dual rectifier diode, Mauve = AC, Orange = DC (which has been replaced here with a new dual rectifier).
    http://audiokarma.org/forums/index....ng-distance-of-the-best.826006/#post-11686575
    I hope this helps.
  12. petehall347
    28,343
    uk.. the middle bit
    the holes are already there if it is the
    au-505
  13. eizner23
    eizner23 Well-Known Member
    551
    Madison, WI
    This thread could use an image of 2x4007 for 10DC. Here is mine.
    Hyperion and Mikelodian like this.
  14. smurfer77
    smurfer77 AK Subscriber Subscriber
    1,562
    San Francisco
    Nice work. I would be tempted to shield the top of that beautiful work, for safety.
