AU 517 cover screw question.
Discussion in 'Exclusively Sansui' started by danb44, Jan 4, 2018.
  1. danb44
    danb44 Member
    99
    Alberta, Canada
    Anyone know the size of the screws for the top cover (4, go in on the sides) and the bottom cover on a AU 517? Mine have wandered away, somewhere. Thanks. - dan
  2. lbcgav
    lbcgav AK Subscriber Subscriber
    779
    Arcadia, CA
    These worked for me:
    -Steel Pan Head Machine Screw, Black Oxide Finish, Meets DIN 7985, #2 Phillips Drive, M4-0.7 Thread Size, 10 mm Length, Fully Threaded, Import (Pack of 100)
    -18-8 Stainless Steel Flat Washer, Black Oxide Finish, Meets DIN 125, M4 Hole Size, 4.3mm ID, 9mm OD, 0.8mm Nominal Thickness (Pack of 100)
    Both were purchased from Amazon for a total under $10 shipped.
  3. danb44
    danb44 Member
    99
    Alberta, Canada
    Thank you very much ibcgav. - dan
  4. nosirrah
    nosirrah Moderator Staff Member Moderator Subscriber
    7,454
    30 min north of seattle
    Aarons general store has them anodized black like the originals were
  5. lbcgav
    779
    Arcadia, CA
    Well, the ones from Amazon I mentioned are black oxide finished. I'm not sure what you mean by anodized. I hope you're not using aluminum screws.
