Not to imply that any of these Sansui models are lacking in Power, but you gentlemen seem to be under the false impression that Power and Volume level have a linear relationship- and the fact is-> they dont. What is meant by the term 'linear' in this case is the false assumption that a 100W amp sounds twice as loud as a 50W amp, and a 200W amp sounds 4x as loud as 50W amp...and so forth. In actuality, in order for your ears to perceive a doubling in volume level, you'd need amp that was 10X more powerful, thus, replacing a 50W amp with a 500W amp.
It is not accurate to say that an amp (receiver) is very Powerful simply because you observe that when the Volume is turned up only a little-ways from zero, that the music youre hearing is already very Loud. For one thing, how can two people who own the same model amp/receiver make an accurate comparison if they both are listening to two totally different speakers? -> and one speaker is more Efficient than the other. (as well as taking into account the size of your listening room, how far away from the speakers youre listening, and the dynamic range of the music itself, all of which are contributing factors) Most Sansui speakers that I know of are very efficient- which means they do not require much amplifier/rcvr power in order for the music to be heard Loud, and there are other brand speakers like that also such as the Infinity SM models- which I have mentioned on AK before.
I have also previously mentioned on AK (check the Archived messages) about the Sansui CA-3000 preamp and AU-20000 integrated amp. Look closely at the numbers around the volume control- the Sansui AU-20000 is a 170 WATT amp- yet to hear the music Loud, you usually have to turn the Volume control up higher- because the numbered volume increments around the dial is 3DB all the way from start to finish- as opposed to most other Sansui models- AU-717, 919 etc..... where the volume increments have a higher initial rate of increase, thus -33DB on an AU-717 is at approx the 10:00 postion on the dial, whereas on the AU-20000 or CA-3000, you have to turn it up higher to approx the 12:00 noon position to get at -33DB, see what I'm saying?
The 'jet plane' analogy is a good one to describe the logarithmic nature of human hearing (as opposed to linear nature). Imagine yourself standing next to a jumbo jet on a runway that has a measured sound level of 130DB (which is about the same DB level as a very loud rock concert or a "nice" jackhammer busting thru concrete). Now, imagine if a 2nd jumbo jet were to pull alongside the first one..... what would the total DB level as perceived by your ears be? The answer is not linear (130+ 130= 260DB). The answer is 133DB. Two jet planes produce (are heard by the ears as) just 3DB more than one jet plane by itself- the logarithmic nature of human hearing is Mother Nature's way of protecting out eardrums from being blown out- which a linear 260DB would surely cause!
As for the term 'dynamic range' - rather than techncially-worded mumbo jumbo, again- analogies are best used to explain concepts. Our ears can hear a wide dynamic range- from the buzzing of a mosquito close to the threshold of hearing to a Loud crash of thunder at the opposite end of the spectrum, or replace the levels in each case with another example- a soft whisper to a loud scream of someone's voice. And what might be an example of limited dynamic range?- well, a musical instrument like a harp - regardless of whether you pluck the harp lightly or more vigorously, the resulting change in volume level is not much different, comprende' ?
B/F
