Need some advice: My AU-919 works fine when started from "cold", but drops a channel after it warms up. Any ideas on what's causing the problem? I can't really afford to take it in to a tech at this point.
Is the Protection light solid or flashing? Sometimes a protection relay will only disable one side. If not flashing then you have may just have an intermittent connection.
