AU-X1 old style board F-2772
Discussion in 'Exclusively Sansui' started by Willy6, Jun 11, 2018.
  1. Willy6
    Willy6 AK Subscriber Subscriber
    1,341
    Pacific northwest
    Anyone out there against cutting the traces and drilling new holes to accept the Omron G5V-2 relay?seems like a better alternative to extending the legs of the new relay and crossing the two rear ones.
  2. Hyperion
    49,218
    Hertfordshire, UK
    Or you could contact Ron (Ronito6) and ask him if he might sell/give you the artwork (or sell you a board) for his updated F-2772 board which includes the footprint for the G5V-2 relays?
  3. Willy6
    1,341
    Pacific northwest
    Got some already but been waiting to see how he populates it before I do.I was just looking at the old style board and it would be pretty simple to cut the traces drill 4 new holes and run jumpers on the trace side rather than extending the relay legs and crossing the rear ones.
  4. Willy6
    1,341
    Pacific northwest
    Or I could try to populate the the new board and hope I don't f#!%! It up because I've never seen the newer version of that board and I'm not exactly sure how it was populated.
  5. Willy6
    1,341
    Pacific northwest
    Ronito6 likes this.
  6. ghamilton
    ghamilton Super Member
    1,532
    ASHEBORO NC
  7. Willy6
    1,341
    Pacific northwest
    So does anyone have an X-1 with the newer style F-2772 board who could enlighten me on what components and their values I need to populate the new boards?
  8. Hyperion
    49,218
    Hertfordshire, UK
    Well, if I understand you correctly I do, I have the later OEM version of the initial (troublesome) F-2772 Phono Mother board.
    As I understand it, the replacement Phono Mother board (courtesy Ronito) is exactly the same as the version I have - but the relay footprints have been corrected - so it's simple really - IF you have other than the Mk1 board to work from. ;)
  9. Willy6
    1,341
    Pacific northwest
    I only have the early version to work from and it doesn't look anything like ronitos copy of the later OEM version is what I'm trying to say.Are the components and their values still the same as the early version ?Looks to me like there are more capacitors on it.
  10. kevzep
    The next X1 I do, I think I will cut the traces, it was a lot of fiddly and difficult work to do it crossing the legs over....
    slimecity likes this.
  11. Willy6
    1,341
    Pacific northwest
    Yes it would be a lot easier that way and if you have 20180610_214544.jpg 20180610_214419.jpg a Dremel drill press like this one you can drill small holes really easy.
  12. Ronito6
    Ronito6 Super Member
    1,199
    Those look familiar. ;)
    That alone will not work. The G5V footprint is different in spacing and orientation. Only 2 out of the 8 leads will fit. You might be able to force the leads in but that is certainly not best practice.
    I guess my point is...make clear that this is all experimental.
    Make certain and provable that your approach will work so that only good info for everyone is shared.
    The new boards are the real way to go. Seeing them installed and working will very cool I think.
    Hyperion likes this.
  13. Willy6
    1,341
    Pacific northwest
    Thanks Ron now that I have the component info I need I'll be populating the new board and using it instead of the old style one
    Hyperion and Ronito6 like this.
  14. Ronito6
    1,199
