So recapping my protection board on the AU517. Did the caps, diode, and fusistors. Literally on my LAST component to replace, which is R05. The service manual says this should be 100ohm, along with R06 07 and 08, but the R05 I pulled from my unit (which was working, and original) isn't 100ohm but instead 1400ohm?! (and it doesn't look stressed, and has a different color code than the other 3 100ohm resistors)
I'd assume I should replace it with the same value, since my amp was working perfectly before, but 100hm vs 1400ohm is a big difference, and I only have 1.2k and 1.5k
So what should I do?!
