AU999 Upper mid harshness?
Discussion in 'Exclusively Sansui' started by afroaudio, Apr 11, 2017.
  1. afroaudio
    afroaudio Active Member
    138
    Cape Town, South Africa
    I have a very nice condition AU999 which I am using as my main amp at the moment. I have done ALL the mods on the unit and recapped completely including large filter caps. Couldnt have done it without all the info from the great AK'er Sansui heads!
    I just did the final "mod" as suggested by AK'er Stereofun which was to balance the differential pair of transistors on the driver boards and replace their associated resistors with better matched tight tolerance variety. This has resulted in a noticeable improvement.. quite surprising really!
    I am not really enjoying my AU999.... But, I have to say I am finding the sound a little fatiguing and the upper mids and highs a little harsh. There is a lot of detail here as well but I find there seems to be an emphasis in that area which is not really pleasant. Just wondering if others have experienced similar with the 999? I should say my speakers are 1970's Tannoy HPD 12 inch drivers in home built 100 liter cabinets. Until recently I was using an AU555A with these speakers which oddly delivers a fatter (maybe less accurate) lower end and none of the harshness in the upper registers.
  2. botrytis
    Well, was the AU555A rebuilt? I think it may be the fact that there is no synergy between the Tannoys and the rebuilt amp.
    savatage1973 and BLAH BLAH like this.
  3. Hipocrates
    Hipocrates Anti-Muppet
    1,408
    Costa Rica
    That happend to me with some Sansui (G-8000, 9090, 9090db, 8080db, 999, 517) and Usher Audio speakers, but they worked awesome with Kef R series, so who knows, maybe it don't match very well with your speakers.
    savatage1973 likes this.
  4. kevzep
    Its not the amplifier, I've never heard an AU999 have those characteristics.
    Could be speaker + Source + human perception...
    What is your source?
  5. slimecity
    slimecity Super Member
    2,355
    New Zealand
    Based on my own experience with comparing the 555A and the 999, I do agree with you. However remember it takes a while to get used to an amplifier's distinctive sound.
    I run my 999 thru Fostex Fe206En's, and these are fairly aggressively "middy" fullrange speakers. Your speakers may be the same. The sound of any amplifier is obviously going to change depending on the speaker match.
    I did find the 555A fat and warm, but also silky in the mids (however unrefined) compared to the 999 (both were fully restored). If its too much with the 999, could you live with it by dialling down the mids on the 999 a bit? The 999 is my "reference" amp - I know that it will sound accurate, and with some recordings, that means its quite "middy".
    Its like listening to reference studio monitors - sometimes the trade-off for accuracy comes at the expense of listening "comfort" I guess.
    BLAH BLAH likes this.
  6. moefuzz
    moefuzz Active Member
    406
    Peeyong Bangyou
    I lived and worked in the recording studio many years ago
    and one thing it taught me was to recognize good versus poorly engineered and recorded albums/music.
    When I am uncertain of an amps performance and need to compare with a known benchmark,
    I reach for an album or CD that was engineered (in the studio) to the utmost standards.
    Over and above the original studio, engineer and production itself,
    I look for albums with no added crunch, fuzz, distortion and/or overdrive etc.
    particularly on things like guitars/bass.
    If you have an album that was exquisitely engineered and recorded
    that also lacks the addition of noise makers on guitars etc.,
    Then you have an album that you can take with you to audition perspective or problematic systems.
    Garbage in garbage out as they say.
    Genesis - Tonite Tonite Tonite at or around the 2:12 instrumental is well balanced and beautifully clean onto record/CD.
    Pink Floyd is known for having many albums that are pure, well balanced and exquisitely engineered to album/cd..
    Or early Led Zepplin, Just the first few seconds of hammer hitting drums on Dyer Maker at moderate to heart pounding volumes will tell you alot about the amp/speakers.
    -If in playing back any of these few ultra squeaky clean selections at mid volumes you again hear harshness then you can at least eliminate the possibility that it's not because of your favorite selections which may or may not be distortion laden before it hits your record needle/CD.
    -No offense but most people don't know how to differentiate between a well recorded album and one that is in itself poorly recorded which ultimately makes it hard to listen to
    Eliminate the possibility that your fav recorded song/s are the culprit with distortion added to the original instruments and/or thru substandard record studio equipment, engineers and techniques and only then can you move on to finding where in else lays the culprit (speakers? amp? input device? etc.
    regards,
    moe of the North
    Hyperion and chevelosm like this.
  7. stereofun
    stereofun Super Member
    1,190
    Tucson, AZ
    Put simply - when the resolution on the 999 goes up, it becomes much more sensitive or "unforgiving" toward A) harsh recordings B) sub par digital processing in your source. It wasn't before I put a world class DAC in its feed that I could really appreciate the depth and resolution without any harshness. I use Wharfedale speakers - they are known for their laid-back-ness. They have a modern slim/tall design with 2 x 6.5 " woofers that covers bass + mid and then a 1" tweeter. Some older speaker designs where you have a huge woofer and then a small mid and tweeter, often to my ears sounds a bit shrill, because the small diameter mid are pushed too hard to balance the large 10-12 inch woofer. This may even be more obvious with digital sources vs vinyl/tape that the speakers were designed around. The 555a almost always sounds good no matter what - but does leave some information behind when compared head on to a modded 999.
    Hyperion, pete_mac, chevelosm and 3 others like this.
  8. BLAH BLAH
    BLAH BLAH AK Subscriber Subscriber
    1,944
    Melbourne. ..Australia. ..
    Ok have to ask...what is the name of that World Class DAC that you have used with your 999....?!?
  9. stereofun
    1,190
    Tucson, AZ
    Hi Blah Blah - It is the 8 channel Sabre 32 ESS 9028 reference DAC. It is used in the flagship Oppo BD-105 with equally good analog section to match.
    BLAH BLAH and slimecity like this.
  10. slimecity
    2,355
    New Zealand
    How about the SACD remaster of Dark Side of the Moon in surround? I know that it sounds gimmicky but man that remaster brought out a lot of previously obscured detail.
  11. pete_mac
    pete_mac Super Member
    2,750
    Sydney, Australia
    Very very true.
    One of the recently refurbished/modded/upgraded 999s that I did for a fellow audio nut here in Australia successfully saw off a number of highly fancied integrated and pre/power amps in a shoot-out. The owners of those other amps were very surprised indeed! A modded 999 is a formidable amp and is actually quite revealing of the source feeding it (which in my experience is fairly rare of a great many vintage amps!).
  12. BLAH BLAH
    1,944
    I enjoy reading the posts about the 999 and the mods by Kevzep/Stereofun...thank you!
    (and am secretly hoping for more special mods! :) )
    I have posted before and waxed lyrical about my modded 999...
    I love its look...
    I love its sound...thank you pete_mac...and Sansui!
    I enjoy listening to my Sansui units in particular the venerable 555A/9500 and the considerable whack of my D11...
    I do find though its the 999 that keeps drawing me back...
    I am hearing resonances in its lower registers I never noticed before..
    The audio shadows/nuances it brings forth are slightly more defined/discernible in the 999's audio inky blackness...
    The lingering thwack of drums...fullness of tenor sax...the bounce of the bass..
    The music breaths and its a detailed journey my ears can follow...
    To my ears and in my humble opinion the 999 excels with detail...in particular the bass...
    I do notice that I have the 999's bass control on neutral...but the mid is set on -2 and the treble at -4...
    Any horn or trumpet playing is sharp as a razor...clear...detailed tending to brightness...piano revealing...
    Ok the speakers are the SP5000 (the Wharfedales are undergoing cross-over work) and the listening room is smallish...
    Definitely not a shy amp!
    skippy124, Hipocrates and stereofun like this.
  13. botrytis
    You mean mid class, Oppo is not considered high end brand (nothing wrong with that). I like the fact they are making other push the tech lower in the food chain.
    This is A WORLD CLASS - dCS Ring DAC (the daughterboard - ALL DESCRETE DAC). Of course you pay for it (don't ask - most houses cost less).
    markkb and BLAH BLAH like this.
  14. stereofun
    1,190
    Tucson, AZ
    Ha ha - if the yard stick is the cost of a house, then everything is mid-class. I am not referring to price but performance. For a DAC the implementation is everything. Oppo hired in engineer legend John Curl to design the analog stage. When the professional reviews came out - the serious ones - the consensus and wording was "world class". The DAC at the time was simultaneously used in the $5000 McIntosh MCD500 as well as in a far more expensive Krell that I can't at the moment remember the name of. Thanks for sharing the beauty above, and I agree Oppo has really raised the bar for how good a bluray player can sound - that was the genius of their flagship BD105D, that for $1300 you get "world class" audio AND video processing, it even came with balanced XLR out, a separate power supply for the analog section and a 2nd dedicated Sabre ESS 9018 DAC for headphone out, which can be used as a pre-amp too.
  15. botrytis
    To me, I have heard plenty of Oppo players, and they are middle of the road in sound quality - video qualityis better than average. If you like them Great, but as I said, they are very middle of the road, nothing wrong with that. I certainly wouldn't say they are 'World Class' Audio.
  16. stereofun
    1,190
    Tucson, AZ
    Fair enough, these are somewhat subjective terms, even for the professional reviewers. The BD-105D, are by the majority of reviews a step up from previous models. Not sure if you have actually heard one.
    Regardless of semantics, my point to the OP was that the quality of your digital source can greatly influence how you perceive your amp. When I got the Oppo, my lesser amps didn't quite benefit from the increased resolution - then the modded 999 went in and it was really an eye opener how that amp could "fill the shoes" and come to live.
  17. NH-MAN
    NH-MAN AK Subscriber Subscriber
    341
    Thank you someone else gets it. So many "audiophiles" do not seem to get this and chase their tails. Good, sounds great, not so good makes listening to some of my favorite songs not so good anymore. It's really is a bummer how you can hear so much garbage in them.
    moefuzz and BLAH BLAH like this.
  18. kevzep
    If you're like me and you are an Audio Engineer and a Musician, you know how to listen past that sort of thing....There is so much great music which is recorded not very well, but why let it ruin the music journey? I am a realist, so the whole Audiophile thing is totally lost on me....
    Music is music and I won't let the fact that something doesn't sound "perfect" ruin my enjoyment.
    We live in the real world, not some fantasy world where everything is "perfect"....
    My 2 cents anyway....
    chevelosm, bd1886, bolero and 6 others like this.
  19. BLAH BLAH
    1,944
    Hi Stereofun...I understand that that oppo BD-105 has two of those sabre 32 ESS 9028 Dacs inside..
    How does the Unit sound?!? and in particular playing through the 999...?!? I am very curious about the pairing...
    I'm also curious to know how exactly the BD-105 help's a listener to appreciate the depth and resolution of the music without the harshness...?!?
    If the 999 only reveals the recording played...and it sounds harsh...how does the DAC help to moderate this harshness...
    What is the process...?!?
    stereofun likes this.
  20. stereofun
    1,190
    Tucson, AZ
    To my ears the oppo has a very natural, detailed and non fatiguing sound with good low end gusto. It's very refined sound comes with a small (and quite acceptable) penalty in the department of attack and dynamics. For that reason the Oppo might be better matched up to either a faster livelier amp or ditto speaker - if that is your preference. The reason I still love it paired with the 999, is that you get to take full advantage of the modded 999's level of detail and strung out mid section as well as the oppo's ability to send some deep refined bass into the 999. For instance, the speedier more rhythmic Eight Deluxe matches the Oppo really well - keeps the Oppo on it's toes if you will - but the Eight D's more dry mid section don't come to life quite like on the 999.
    Audio is all compromises eh ? but as Kevin says, we shouldn't get caught up in that. In short, I'd say that the oppo and 999 is a fantastic match if your preference is spades of detail and laid back refinement over punch and bravado.
    How exactly the Oppo does audio so well, I cant tell. I do know that Oppo uses a separate ring transformer and subsequent power supply just for the audio section and that Audio legend John Curl was hired to design the analog part of the audio section. The build is impressive - a beautiful display of symmetry, organization and shielding, among a sea of red wima caps and otherwise Silmic II's .
    I am really no expert in the DAC - Rather than say the 999 only reveals the recording played, I'd say the 999 eminently projects the signal it happens to receive to a nice authoritative sound stage. If that comes from a digital source that is sub par, well that is what you get, no way around that. It can't mask a bad recording - Back to black, by Amy Winehouse for all its great songwriting still sounds flat and harsh, even in 24/96 - But it does sounds flat and harsh projected eminently well...if that makes sense. What I have noticed is that some of my older disc that has been played on multiple systems through the decades sounds decidedly more refined on the Oppo, they may still have a late 80'ties harshness to them, but it is still more refined and can via the 999's excellent and clean tone controls become pretty darn good.
    By the end of the day I think it is simply a matter of a very very good DAC (Happy now Botrytis ;-) - matched to a very well designed analog section by someone who really knew what he was doing.
    Hyperion and BLAH BLAH like this.
