0kazaki101
New Member
I recently got a hold of a cheap beFree Sound BFS-440 5.1 Channel Surround Bluetooth Speaker System.
After a few weeks of the unit working completely fine, there came a day where an audible 60hz hum started coming out of both right speakers (front and back). The first day it started, it wasn't bad. After around 2-3 days, it got to the point to where I had to stop using the right channels all together because the humming got so loud and obnoxious.
I've done a little bit of troubleshooting, and here is what I have done.
What I am asking is this:
Any thoughts?
- Unplugged the whole system and put it on a different circuit in the house. Same hum.
- Plugged different speakers into the outputs making the hum. Same hum.
- Took the unit apart in order to see any incorrect grounds. Nothing. Same hum.
- Tried selecting different inputs. Same hum throughout each input.
- Tried changing the volume to see if there was a problem with the amplifier or inputs. Same hum without getting louder or quieter.
- Removed all inputs. Same hum.
- What could be causing this hum?
- Why is the hum only coming out of one (or two) channels?
- Is there a way to fix this hum?
- Are there additional steps on troubleshooting that I can do to isolate this hum better?
Any thoughts?
