unless its a piece of absolute trash ; blown xformer or other major issue. if it is cheap I'd buy it
Only problem to be wary of, is that if it shows signs of heat distress on the circuit board, it may be a problem child.
I know of at least one of these amps, locally, that's been passed around from hand-to-hand, because NOBODY can get it to be totally "quiet". Leakage from carbonized/overheated circuit boards causes little cracking and ticking sounds in the background, no matter what.
I don't know of any solution to this, other than changing out the entire circuit board...
Regards,
Gordon.
Yep. That is the problem with the really old units. Baked-boards will eventually cause problems. The other issue is that an amp that old will have to have been recapped at least once, and will probably need it again pretty soon. And circuit boards traces don't take kindly to very many solder-unsolder cycles.
But, if the unit is in decent shape, that is a very nice sounding amp. Personally I prefer the sound of the 6fq7 based ARC circuits over the 6dj8 based circuits.
I'd say no matter what, even with a complete strip of components, cleaning and a baking in the oven, the board would probably be suspect.
All the sockets and pots would need to be replaced as I wouldn't trust them with the corrosion pictured, even with a good cleaning.
I'd take it on as a project in a heartbeat, but I'm also a rather deranged glutton for punishment.
I have had one of these !I have a chance to pick one up one the cheap....working condition unknown. Wondering if this guy is worth the gamble.
My circa 1976 D76A is still intact after hundreds + of hours of use !!
Just went through it`s 5 year checkup 3 months ago, and only needed one original small tube replacement..
Caps, circuit traces, performance checks all checked out ..
It is a sonic space heater, but in NE. FL. it hardly gets cold often enough for heating up my room except the few 40` or below nights..
Just remember it`s output is out of phase with any other amp that might be used with it(Bi-amp for example).. Just my added $.02 worth input.. Regards, OKB
I really wonder how this worked out for the OP,as the thread died out four years ago.Unless there were transformer problems,it was certainly restorable,but these can scare off the most experienced techs due to complexity. I am a huge Audio Research fan myself,and work on them regularly.I can really relate to the ''sonic space heater'' comment,but up here in Canada it cuts down on the heating bills,so everything works out nicely Here's my D76A rebuild:
http://audiokarma.org/forums/index.php?threads/audio-research-score.675148/
