But why buy a new turntable and tinker with it which would void the warranty.
No I am hereOP is MIA.
IDK about Schitt Mani & Music Hall, but I /do/ own LP120. I've had mine for exactly 1yr now, and without any problems whatsoever. There seems to be a lot of hype about LP120, people are saying this or that, but for what it's worth I'm more than happy with mine! But you should really look into swapping out the cart, as the original 95E just doesn't sound right, not to my ears at least ... but that's a matter of personal taste. The one I ended up using on a regular basis is the vintage Shure M75 ED/T2 with JICO stylus. Not the S.A.S one, just a standard 0.3x0.7mil elliptical. It gave a whole new voice to my LP120 and sounds tons better than it ever did with 95E.Both can be had for $299.00.
Which would pair better with my Schitt Mani?
Which would have a greater upgrade path later own?
Which have the better tonearm and cartridge out of the box?
mmf-2.2, hands down. I've had mine for four years. But one word of advice: DO NOT try to change out the cartridge by yourself! It's a nightmare. But I would definitely look at its replacement, the mmf-2.3
It's not that hard if you're patient and have some micro tools like a small flat blade screw driver and some decent tweezers. It's not something I would do on a regular basis but two or three times a year will keep those tonearm leads from getting fiddly.I'm curious, what is it about the headshell on the mmf 2.2 that makes changing the cartridge such a nightmare. I'm currently looking at the mmf 2.3 as it seems to be the best table in in its price point with adjustable VTA. But I wonder, is it a pain to change the cartridge on the 2.3 as well?
Sorry. Total newbie question here: What do you mean by "tonearm leads becoming fiddly?" Is the above something one should do a few times a year to keep the leads in good working order or only when one needs to change a cartridge?It's not that hard if you're patient and have some micro tools like a small flat blade screw driver and some decent tweezers. It's not something I would do on a regular basis but two or three times a year will keep those tonearm leads from getting fiddly.
I am not sure what "fiddly" means in this context
The AT95E is well regarded and probably a better a cartridge than the rebranded lower end Ortofon that comes with the MMF2.2. There are number of stylus upgrades for the AT95E and the removable headshell of the AT LP120 tonearm makes changing out cartridges relatively easy. The Magic2 cart on the MMF2.2 could probably take some Ortofon stylus upgrades. The alloy platter on the MMF2.2 can be upgraded to an acrylic platter for another $130.
You must have gotten an early version of the 2.2. Mine came with the Tracker, which was a rebranded Goldring Elektra.
The Elektra is a rebrand itself made by a Japanese OEM. You used to be able to get unbranded ones for $20-30 or maybe even less. I think Pfanstheil (sp?) still has their version.
