BinaryMike
Pelagic EE
Replacement turntable drive motors for these models have become nearly impossible to procure, so I decided to attempt replacement with a motor from the Beogram 2400 series. This item carries part number MHN-3P2RDS. Physical fitment isn't a problem, but hookup and tacho (FG) output frequency differ markedly from the original MHN-5P2RDS. I solved the hookup difference with a simple adapter so as to avoid burning any bridges:
I wasn't able to reverse-engineer the servo control circuit to my satisfaction due to the lack of a datasheet for the IC, but a comparison of the 2400 and 4004 schematics allowed me to deduce that one or two capacitor value changes might be sufficient to accommodate the FG frequency difference. After a bit of calculating and experimentation, I ended up replacing 1C3 with 39nF (was 220nF) and 1C7 with 1.0nF (was 47nF). I'm not sure what 1C7 is doing in this circuit. I used the value found in the 2400 schematic and didn't alter it after determining a new value for 1C3. Both platter speed settings are now well within range of the on-board trimmers. There's no perceptible speed drift with a polyester cap at 1C3, and speed settles with authority after perturbation. I'm too lazy to hunt down my W&F test record, but piano recordings sound good.
