B&W DM6
Discussion in 'Speakers' started by stevo137, Mar 19, 2017.
  1. stevo137
    stevo137 AK Subscriber Subscriber
    2,234
    I searched but not much out there.
    Can some one here that owns or has owned these please provide some input?
    Do they need the legs to optimize sound?
    Any other input will be greatly appreciated.
  2. turboyam
    turboyam The Kenwood fan!
    1,093
    Quebec Canada
    Those are awesome speakers and did come with stands, steel or aluminum.
    Others will chime-in.
  3. The Fuxtor
    The Fuxtor AK Subscriber Subscriber
    2,162
    Calgary, Alberta
    yowzers!look nice!!
  4. jcamero
    jcamero The sun will shine in my back door someday Subscriber
    3,111
    The Dark Star
  5. bobins08
    bobins08 AK Subscriber Subscriber
    4,939
    St. Louis, MO
    I have a pair and I love them. I think you have to spend big coin to beat them today. Yes they came with cast metal stands. One "upgrade" I read about is to make wooden box stands filled with sand to set them on.
    I am out if town, when I get back in Tuesday I'll measure my stands for you. You need to get them off the ground to make them sound their best.
    Before you play them make sure the fuses are correct per the manufacturer spec. DO NOT risk blowing a tweeter. You will have a hard time replacing them.
    I posted a thread here on my crossover recap which made them sound much better.
    stevo137 likes this.
  6. stevo137
    2,234
    Thanks much for the input Bob!
    The best I can do is use these until I find the legs because of WAF.
    These are very solid heavy wood pieces and this has already seemed to help the low end become more defined but I will need to get the stands.
    I can see why there are those that like these.
    They seem to say, just give me a good home and I won't disappoint you...
    No worries, I already ordered the correct fuses.
    Ds2000 likes this.
  7. stevo137
    2,234
    I know it's a bit of tabu but the Modulus sing with these and I don't hear any sonic wrestling, interference etc.
    Modulus attenuators little above midway.
    Running two channel from the Epicure M1.
    The heavy wood pieces isolated them well and definitely improved low end and I have two on each side so I can make these any height that I want using steel tubes on the four corners.
    Don't think I need to do that though.
    I'll give em' a bit of cleaning tonight.
    These speakers border on my "if I can't carry them I don't want them" rule but I can carry them!
    cratz2 likes this.
  8. sax6
    sax6 Loudness always ON
    1,829
    Province de Qu├ębec
    They call them '' the pregnant penguin '' speaker.
    Would like a pair of B&W... someday ( DM2 )
  9. bobins08
    4,939
    St. Louis, MO
    Mine were very rough shape, yours look great.
    I think you might want to try check your midrange for sag, if so flip them 180 degrees. One if them looks a bit saggy, but that could be the camera angle.
    I flipped my mids and woofers. I also needed to re-glue my woofer rubber surrounds in a few spots.
    I re capped the crossovers and they sound much better. There are 3 electrolytic caps that could use a refresh. I replaced the remaining box mylars too.
    Here is a link. You get to the crossover through the woofer opening. It is screwed to standoffs on the bottom of the cabinet.
    http://www.audiokarma.org/forums/index.php?threads/my-b-w-dm-6-recap.537697/
    Cheers, Bob
  10. MarZutra
    MarZutra Addicted Member
    5,074
    New Scotland, Canada
    Way to go broski! Nice amp, nice pre and very nice speakers. There was a pair of those on the block around here, fairly recent, and they did have black metal stands/feet with them.
    cratz2 likes this.
  11. stevo137
    2,234
    Thanks Mar!
    My Epi M-4 needs to go to the doctor like yours did!
  12. stevo137
    2,234
    Thanks for the input Bob!
    Okay back to normal, no Modulus, it was fun to goof around a bit.
    These sound great just how they were designed.
    Just need to get a subwoofer for the Modulus and they're for the living room setup.
    They look like little mice there but when set up right they will kick some arse.
    cratz2 likes this.
  13. stevo137
    2,234
    IMG_2344.JPG A few scars, so don't we all have a few?
    I'll take care of these and you won't even know they had them.
  14. MarZutra
    5,074
    Yeah. Mine ended up having a total rebuild. Now it's good for another 40 years. Yeah, a hot iron and a good sanding will bring all those dings and scars right. Nice score!
