Hello, since it looks like there might be some variation during production on the BA5000 I'm hoping someone might be able to confirm whether a couple of the components on the buffer board of my ba5k are the correct values. This amp came off the line in 1976.
I'm trying to track down some distortion in the left channel that is showing up on the scope, and have traced it back to the buffer board. Since I'm going to pull the board, I figure now is the time to recap it. But in comparing the schematic vs. the actual board before ordering caps, I've found that the buffer board layout differs from the service manual that is available on HiFiEngine.
The schematic indicates C604 as being a 63v 47uf, which is present, but the board in mine also has a C605, not on the schematic, that is a 50v 47uf cap. Also the 5w R618 on the schematic is listed as 270ohm while this resistor on my board is 150ohm. Also, in what appears to be a slightly different layout, on my board R616 is mounted on end as opposed to horizontally as in the few photos I've found online.
This board is a little buried, so until I pull it, it's tough to determine whether the caps look to be original.
Any info would be appreciated- Herb
