"banana jack" plugs for Dynaco a25's?
Discussion in 'Speakers' started by jeffp6155, Jun 23, 2018.
  1. jeffp6155
    jeffp6155 New Member
    14
    Hi, can someone recommend a set of plugs for 16 gauge speaker wire that would be a good fit for these speakers? Also, what is the procedure in terms of connecting the speaker wire to the plugs and then the plugs to the speakers? Thanks very much in advance.
  2. KevinJS
    KevinJS Lunatic Member
    I use these from Monoprice. They don't require any soldering or screws. The body of the plug unscrews, the cable is fed into the lower part and clamped into place by screwing the two parts together. They will accept up to 10 gauge speaker wire.
    I'm not familiar with your speakers, and am making the assumption that they have binding posts which will accept banana plugs. If so, just plug them in. You may need to remove a small plastic insert from the post before you can insert the banana plug.
    If not, the same plugs are available with pins instead of plugs, or you may be able to use spades, like those from Sewell shown at the other end of these patch cables I made to replace some missing speaker parts.
    All of these are available from Amazon.
    jeffp6155 likes this.
  3. WaynerN
    WaynerN AK Subscriber Subscriber
    5,789
    Minnesota
    Use dual banana plugs.
  4. musichal
    11,575
    Norman OK
  5. Blue Shadow
    21,943
    SE PA
    The A25 has standard 3/4" spaced dual binding posts that will accept wire or banana plugs. I would get dual banana plugs which are a standard 3/4" spaced and this will prevent a + banana plug from touching a - banana plug and damaging the amp.
    The crappy chinese dual banana plugs will peel and if you use them with wire the screw is not threaded to the end and will not engage if you don't use small enough wire.
    I would get a pair of Pomona dual banana plugs. They are the quality stuff.
    To use them, identify the side of the wire you want to be the black, negative, terminal on the amp and speaker. Unscrew the grub screw in the banana plug, insert the wire and tighten the screw to secure the wire. Don't tin the wire except on the very end as under pressure the solder will flow and cause the set screw to become loose as the solder squishes under it.
    Repeat the connection for the positive, red side of the wire. Hook them to the amp and plug em into the speakers and you good to go. Most dual banana plugs have a tab and label it gnd. This helps you keep the polarity of the system correct, doing both speakers the same.
    musichal and jeffp6155 like this.
  6. jeffp6155
    14
    thanks alot for all the informative suggestions! before i even get started with this, i need to resolve one issue that i'm hoping is simple: one of the two locking nuts is stuck on the post and by turning it either way to tighten or unscrew moves the post along with it. I would think that using a tool to hold the post in place while I gently attempt to align the nut properly so it turns is the solution.
  7. KevinJS
    Well, it SHOULD be simple. The only reason for unscrewing the binding post would be to use spade connectors or bare wires. Banana plugs should just plug straight in. Loosening and tightening the post doesn't change the size. The plug itself grips the post.
  8. Blue Shadow
    21,943
    SE PA
    To tighten the binding post you need to pull the woofer which is a small project on reinstall.
    Google images of the crossover and see that each post is bolted into the cabinet. The nut inside needs to be tightened and maybe loctite would keep this from happening again. But what you have is 45 years old give or take.
    The deal with the woofer is not damaging the mounting location since the screws can pull out some of the particle board. No problem you can repair any issues as needed. Just ask if you need to.
    If you want to install a new dual binding post don't let the shiny yellow metal glitter in your eyes and sway you away from professional quality like Pomona. This brand is all over professional test gear that has much lower and more critical signals than some speaker. Quality before shiny metal.
  9. spark1
    spark1 Super Member
    1,749
    The Great Midwest
    I think you need to access the other side and tighten the nut on the inside (by removing the woofer).
    jeffp6155 and Oerets like this.
  10. transmaster
    transmaster AK Subscriber Subscriber
    8,597
    Cheyenne, Wyoming
    I used and bumped these banana plugs. The problem I had with these was the threaded front section kept coming loose. I could not tighten enough. What you want is a one piece body. I have Nakamichi branded locking banana plugs they are very good. The only problem I have with them is they are rather long. The bottom line is as I said about you want a one piece body. 4D588B5E-C6C3-4FF0-A3E3-B52F34C189F5.jpeg 2EB947DD-4E53-4212-8B6F-2DFC420CB19F.jpeg ECFA5737-9704-4E4D-94C0-CF943799A385.jpeg
    boza and jeffp6155 like this.
  11. transmaster
    8,597
    Cheyenne, Wyoming
    :lurk:
  12. nj pheonix
    10,151
    New Jersey
    IIRC ( and i certainly may not) i thought my A25s had screw terminals:idea:
    Nope i'm wrong .
  13. transmaster
    8,597
    Cheyenne, Wyoming
    Is this the speaker? If so their is nothing better than the spade connector.
  14. Roadrash
    Roadrash AK Subscriber Subscriber
    889
    St.Louis MO
    How much do you want to spend on plugs?
    I use these Neotech_NCB-80-960.jpg Neotech NCB-80. I got them from Sonic Craft. (site sponsor)
    And these KIMG1154.jpg Furutech FP-202G. I got these through Douglas Connections.
    Neither are cheap but they are very nice, and are super easy to install on the wire. No soldering required and very secure.
    jeffp6155 and transmaster like this.
  15. transmaster
    8,597
    Cheyenne, Wyoming
    Going cheap on connectors does not always work out. As I found out with the Monoprice plugs. But things can get outrageous. I would have loved to have used Cardas binding posts on my 10B crossovers but it would have cost almost $100 dollars. After rebuilding the crossovers on the Wharfdale W35’s I was reacquainted with just how good, and simple an old school sold brass screw with a Thumb nut is. For the $50 bucks one pair of Cardas binding posts costs you can purchase enough copper screws, bolts, and thumb nuts to refurbish a bunch of speakers with a connection that is every bit as good as anything no matter the price.
  16. jeffp6155
    14
    i have a set of budget plugs i think i had bought from meritline a while ago and the wire doesn't tighten from within nor does the pin stay snug inside the speaker. so i'm hoping one of these options provides a good fit.
    also, from what i'm gathering reading the comments not being to turn the locking nut is not an issue in terms of simply inserting a plug, so that's one less thing. thanks again for all the valuable responses.
    transmaster likes this.
  17. awillia6
    awillia6 Super Member
    1,382
    Good points on the Monoprice cheapies. I still use them routinely, securing the plug section with a bit of threadlocker. A more serious problem with them is that the spring steel in the plug deforms, quickly and almost totally losing its ability to "grip" the female jack solidly. Not good to have your speaker plugs rattling around loosely in their amp jacks. I've found slipping a smallish slotted screwdriver into the spring sections and re-bending each of them restores the lost grip (at least for a time).
  18. transmaster
    8,597
    Cheyenne, Wyoming
    Of all of the banana plugs I have used this is the best design. I use them on the vintage test equipment I have which uses banana plugs for the test leads. They work particularly well with sockets that are worn from years of use.
  19. awillia6
    1,382
    Source?
  20. transmaster
    8,597
    Cheyenne, Wyoming
