marcus oakly
New Member
hi
i am after buying a 5 in1out hdmi splitter with the very latest specs
WIDE COMPATIBILITY: FiveHome hdmi switch works with all HDMI-integrated devices,such as PCs, laptops, fire stick,gaming consoles (XBox 360, Xbox One, PS3, PS4), projectors, TV receivers, TVs (including smart TVs), VR and others. Supports all common audio formats. Dolby Atmos, DTS: X, LPCM 7.1, DTHD, DD +, Dolby True HD, etc. Several devices can be connected in series (cascadable)
i need the switcher to support a sky q box virgin v6box buzz tv xls 3000 box ps4 pro xbox one x scorpion edition xbox a pc sony ux 800 4k player nvidia shield console wii u a 65e6v oled tv thanks
which hdmi splitter is the question
- ★4K ULTRA HD 5 IN1 OUT: This HDMI Switch connects up to 5 UHD HDMI sources on a single display and easily switchs between 5 sources. Support bandwidth 18Gps/600MHZ, HDCP 2.2, 4K 60HZ 4:4:4, FullHD, UHD, CEC, DeepColor to 36bit. with high dynamic range if possible support 120hz at 1080p
- ★HIGH RESOLUTION: Monitor switch supports up to 4K@60Hz resolution including Full HD 3D, 1080P. Back compatible with V1.4 and V1.3 . HDMI passthrough switch supports HDCP 2.2 as well as HDCP 1.4
