Similar Audio Humour,ya gotta read this!!
A few years ago I suscribed to an audio magazine that gave ideas to improve your sound in an audio advice section...a person wrote in with the following problems and they replied with some "Sound" advice...it went as follows..It is why I am writing,so you could give me the straight goods with no jive takin' like in the other high fidelity magazines.Here is my system:Candle Symphony amp,with radio, eight track,cassette and digital waking alarm clock...Realistic loudspeakers,model Minimal.. 2 1/2 in. 25 watts rms/channel,full range one way active driver. Newly installed,and mounted on the tops of my old cheap speakers to the correct hearing height,on spikes,actually sawed off Phillips-head screwdriver blades.My main source is the Yorx 756/A single play,belt drive,auto-speed ...modification: dust cover removed,turntable mounted on polyester fibre-fill throw cushions.Are you familiar with this model?It is Swedish,I think.The cartridge is the Empire,non ceramic,with newly-adjusted stylus.Here is my problem.When I listen to some types of choral intrumental music,the definitions in the brass,nickel-plated instrumentation losses the edge of the first attacking note.It does not "grab the throat" at first,but it is there.And on much of my Gospel collection,in the larger cathedral recordings,I think I can hear smearing of the vocal singing in a large choir,but mostly to the left side.I think it is caused by the time smear,an interpolation of the fundamental harmonics in the quintessential nature of cyclic chordal soundwave frequencies,or maybe by my speaker cable?I am thinking of either new,better loudspeaker ultra high fidelity cable,or LC-OFC silver-Litz wire headshell cables for my turntable
r should I modify my speaker placement to eliminate time smear and vocal indistinctions?...What is you thinking, please?...the magazine replies:....We would modify the speaker placement.More specifically we would place the speakers as far away from where we lived as possible.Next we would get a good turntable technician to check the turntable's auto-speed, tomake sure it does not go faster than an auto,namely 50 km/h, less if you live near a school. And before we spent money on oxygen-free wires, we would check that the throw cushions under the turntable were kapok-free.The definitive technical paper on the effects of kapok on audio was published in the Autmn 88 issue of the Polyester Growers Quarterly.You might also check to see whether the nickel plating on the screwdriver blades under the speakers is compatible with that of the offending instrumenst.We are surprised that the sound of your Candle/Yorx system doesnt "grab you by the throat".The last time we heard one(our local K-Mart,which we like because they have such large listening rooms), that was certainly the way it grabbed us....Enjoy your Music...Kenny
