I have a horizontal bi amp situation and I want to be able to switch between a tube amp and a ss amp for the top end. I have a impedance matching two amp speaker switch, now this should be doable? Or is there something I'm missing?
Do you mean with my other one for the lows? Thes two amps are just for mid and tweeter so I don't have to warm tubes for a short timeAre we not worried that the 2 amps will have different gains?
Yes, all three amps have gain controlsNo, I am not really talking about that. Many amplifiers have different levels of gain, in relationship to the volume control. With one amp, it doesn't matter, but with 2 or three amps in a bi-amp or triamp configuration, the tonal balance between the woofer, mid and tweeters will be screwed up. Many tube amps have a gain that can be as much as 10db lower then their solid state cousins, so that means one amp will be playing at one volume level, the other amp at another level, and the blend of the 2 will not mix correctly. The result (depending on the amps gain level) could result in a bass heavy, or high frequency heavy playback.
However, if your amps have volume controls, you can adjust for this, simply by adjusting the volume for each amp.
No, I am not really talking about that. Many amplifiers have different levels of gain, in relationship to the volume control....
Yeah, but others might also try bi-amping, and some of the issues need to be brought out in the open of how this can be problematic.
Simple solution, you would use a stereo 3-way, electronic crossover. They have individual vol. controls for each crossover output. This is an old concert sound procedure.No, I am not really talking about that. Many amplifiers have different levels of gain, in relationship to the volume control. With one amp, it doesn't matter, but with 2 or three amps in a bi-amp or triamp configuration, the tonal balance between the woofer, mid and tweeters will be screwed up. Many tube amps have a gain that can be as much as 10db lower then their solid state cousins, so that means one amp will be playing at one volume level, the other amp at another level, and the blend of the 2 will not mix correctly. The result (depending on the amps gain level) could result in a bass heavy, or high frequency heavy playback.
