toxcrusadr
Omelette au Fromage
I’m looking at the crossovers from litefootdan’s pair of Hartley Concertmaster VI speakers. These are massive speakers with a special 24” woofer. Hopefully Dan will post some pics and info here or in another thread, but in the meantime, I need to pick your brains about the crossovers. Dan wants to biamp these and I volunteered (in a beer and BBQ induced haze at the KC Twangfest gathering at Jaymanaa’s last spring ) to look at rebuilding the crossovers. I would like to tap the collective brain on the proposed plan.
Here’s the stock crossover schematic drawn from the crossover itself (I didn’t find one online). Pretty standard 3-way except for one item.
Notice how the woofer input doesn’t come off the +input but is tapped after the 0.28mH midrange inductor, L2. It then goes through the 3.75 mH L4 into the woofer.
Dan wants to biamp these so as to maintain the crossover circuitry for all the drivers and create two inputs, one for the woofer and one for the mid/tweeter. They could still be strapped together to run with 1 amp.
Here’s what I figured. The woofer has a total of 4.03 mH in series with it. In order to maintain that inductance for the woofer circuit, since inductance is additive, we could disconnect L4 from L2 and either add in another 0.28 mH in series with it, or get a 4 mH inductor to replace L4 (now called L4A, which looks like L44 in my chicken scratch). The mid circuit still sees the original 0.28 mH on its input, and the woofer has the same 4 mH in series with it.
Dan says that Hartley said they didn’t want to do this mod because of something about overlapping. I am not sure how this crossover behaves in the mid/woofer crossover region - does the design do something with the slopes that would be lost here? I considered that maybe they did it to save money on inductors, but with a high end speaker like this, the difference between a 3.75 vs. a 4 mH inductor is peanuts.
How would this change affect the performance? Is the solution really as simple as I've drawn it or is there more to it?
