rulerboyz
AK Member
Now that I've worked out the bias problem I tested the sound on the KR-4140 receiver. Alas it isn't really there (yet). What I am getting is a somewhat subdued distorted sound that only comes through when I crank it 3/4 of the way up. Also, when I am listening with earphones I get a moment where the sound clears up and comes in louder at the moment just after I press and release the on switch. I have noticed this exact same behaviour before several months ago on an different KR-4140. Before I worked on solving the bias problem I was getting good sound in one channel, and not too bad on the other (the channel with the bias problem). Has anyone encountered a similar distortion behaviour (where sound gets better temporarily as the power turns off)? Any ideas what the cause may be? The small transistors all appear to pass the bipolar junction transistor testing, at least while embedded in the circuit board (I didn't pull any out to test).
Update:
Something I remembered. I suspect that it is probably two small npn transistors on either side which were both directly involved (on separate occasions) in a blowout of a power transistor (replaced the bad power transistors but I overlooked checking the smaller ones). I'll pull them out and do a transistor test on them.
Update:
