amr2
Well-Known Member
Hello
I finished a rebuild of a Yamaha M80 months ago thanks to this site. Output devices, drivers, pre-drivers, bias transistors, bias pot, all diodes and some resistors have been changed, on both channels. Seems to work fine, but something related to the bias setting is annoying me, so I have decided to create a new thread.
The amp is biased to 10mV across the emitter resistors. When I turn the amp on R channel starts around 6mV, and L channel around 2mV. Both rise slowly close to 10mV in less than 5 minutes. The voltage remains quite stable over time without input signal.
If I play a sine signal (1KHz) using a dummy load, and stop it after a while, R channel returns to the nominal bias faster than L channel. It remains about 6mV higher, and slowly it goes down to the nominal value (1-2 minutes)
Perhaps any component that I have not changed needs to be revised, so I would like to understand why one channel starts higher than another, and what components of the schematic generates the initial drift when the amp is powered on. I have a digital oscilloscope to measure whatever. This is the schematic:
http://akdatabase.com/AKview/albums/userpics/10004/Yamaha M80 Schematic with TSB66.pdf
Any suggestions are greatly appreciated. I apologize for my basic English.
