Bought this European 5010 Cassette Deck from another member today. Thanks again! Your gear was amazing!
After a thorough cleaning I was able to get it singing again. I've taken an inventory of the electrolytic capacitors and will be ordering replacements. I still need to get the repair manual.
There are some things I could use a hand with:
The door doesn't sit quite right. There is a lot of play in it, causing it to rub and not open when the eject button is depressed.
Are there any other problem components I should replace?
I will probably replace the diodes.
There are some minor scuffs in the faceplate. Does anyone have suggestions on making them at least less noticeable? I have seen some aluminum black for firearms that I think might do the trick. Has anyone used it?
It sure is pretty!
It sure is pretty!
